Old 07-17-2016, 11:23 PM   #1
1977 Argosy 28
2000 28' Excella
Michigan City , Indiana
Cool Tail Light Issues on '77 Argosy
I am just getting started on restoring a '77 Argosy. I have a few working marker lights but no tail lights. The pigtail plug had one terminal that was missing from corrosion so I started the project with replacing that.
With the old connector cut off, I am applying voltage directly form my TV battery to the pigtail wires. I can get the markers that I had and the brake/turn lights to come on, on both sides. I have no running lights in the rear and no backup lights.
My questions are:
Are these fused somewhere inside the camper?
I found the terminal strip where the pig tail connects at the street side of the gaucho. Is there a place in the rear that I can get to without removing interior skin to check for loose connections?
Any help is appreciated.
Buck Rabbit is offline   Reply With Quote
Old 07-18-2016, 06:04 AM   #2
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Photos in the thread linked below might be helpful. I found this using the search function shown in the solid blue line at the top of the page. There are two blanks in the drop down tab. I find that the Google custom search works best. In this thread one of the forum members offers a pdf wiring diagram of a 77 model. You might click on the user name and send him a message asking for a copy.
http://www.airforums.com/forums/f37/...ics-69394.html
Check ground at each light. Each light is grounded to the trailer skin via the screws or rivets holding the fixture on. Cleaning/removing corrosion will help
Alan
LED light kit for the Monarch stop tail and turn light Dan@LED4RV Commercial Listings 6 07-03-2018 12:26 PM
Tail Light and Marker light lens 68 TWind General Repair Forum 0 06-26-2014 12:34 PM
Leak near tail light, but it's not the tail light adwriter73 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 03-31-2013 12:34 PM
'71 safari tail light/brake light issue TGK Lights - Interior & Exterior 8 08-20-2011 06:45 PM
