Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 04-29-2007, 05:02 PM   #1
blueline
Profile:  1967 22' Safari
Lake Oswego , Oregon
Tail Light Always On
Hi,
I have a problem with my 67 Safari, where the right rear tail light is continuously lit when connected to the TV. The marker lights and left stop/signal lights all work fine. I checked the wiring on my TV, and everything works as documented.
Is this a short? I'm not sure, as I'm not blowing fuses. I don't think it's a ground issue, as it wouldn't work at all.
I'm stumped, so any help would be greatly appreciated.
-Gary
blueline is offline   Reply With Quote
Old 04-29-2007, 05:43 PM   #2
Shacksman
Shacksman's Avatar
1960 28' Ambassador
Avonton , Ontario
Open the trailer connector and see if there are any stray wire strands touching from the charge line to the light. Sometimes the wire will fray and cause theses stray lights.
Doug
WBCCI #3327 - VAC
73 Argosy
67 Safari
60 Ambassador Int.
Shacksman is offline   Reply With Quote
Old 05-05-2007, 04:55 PM   #3
blueline
Fixed
Thanks, Shacksman! I took the cover off the trailer side connector, and calling it a mess is putting it mildly. There were wires that were not connected, half connected, etc. I cleaned it up and reconnected all the wires, and everything works now!
Outlet under sink, night light LI Pets Electrical - Systems, Generators, Batteries & Solar 5 09-24-2006 06:25 PM
'66 tail light bulbs Derk Lights - Interior & Exterior 8 01-28-2006 10:43 AM
two tiny orange lights on left front side trailer overlander Lights - Interior & Exterior 19 12-12-2003 08:39 AM
left back-up tail light Margo Schock Electrical - Systems, Generators, Batteries & Solar 6 12-16-2002 01:52 PM
Bargman #99 wedding cake Tail light needed cindy Lights - Interior & Exterior 8 10-16-2002 09:52 AM
