Old 05-26-2012, 09:27 AM   #1
2010 27' FB International
pocatello , Idaho
Switching out inside lights to LED
Bought a few LED light bulbs (if bulbs are the right word for LED's) to replace halogens inside our Airstream to conserve power. Cannot figure out how to get old bulbs out. Called dealer, and was told the fixtures are spring loaded, so you have to pry them out - suggested a screw driver. I have tried, but not coming easily and am afraid of scratching ceiling if I try harder. Any suggestions?
Idaho air is offline   Reply With Quote
Old 05-26-2012, 09:29 AM   #2
Flysoncloud's Avatar
1953 21' Flying Cloud
Wentzville , Missouri
If they have been in there for a long time they may have a tad of rust on the metal side. I would hit them with a little WD40 and let that sit for a while.
I have read about the evils of drinking beer so I quit reading.
Flysoncloud is offline   Reply With Quote
Old 05-26-2012, 10:51 AM   #3
2007 27' Classic FB
Ridgefield , Washington
Images: 11
Recently replaced a number of bulbs in the Stream with LEDs. The only ones I remember having some trouble with were the puck lights and it took a good hard pull to get them out. Good luck!
John
Woosch is offline   Reply With Quote
Old 05-26-2012, 11:03 AM   #4
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
The springs are pretty tight. I tried a butter knife (less likely to scratch) between the inner and outer rings to it out and then pulled it out with my finger. The butter knife didn't work very well, so I switched to the blade on a Swiss Army knife and tried to be very careful. If you slip with your finger, it can bite. You could put tape on the rings and around the fixture to prevent slips that scratch, but I just went for it. As you figure it out, it gets easier. If you scratch anything, don't worry, no one (except you) will ever notice it. So long as you got good quality LED's, they should last for many years and you'll never have to do it again.
Gene
Old 05-29-2012, 10:52 PM   #5
Dan@LED4RV's Avatar
Denton , North Carolina
plastic
I have gotten a platic sheet rock putty knife and cut it into strips so they would be about 5/8 in wide. Then follow the picture below.
By the way. I used a knife here but learned the hard way. You can scratch them. The brass lights are harder to replace than the Brushed Nickel.
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
