Old 04-26-2012, 04:44 PM   #1
btowntincan's Avatar
Mercer Island , Washington
switching marker lights
Is there a way to turn on your marker lights, independant of being hooked up to your tow vehicle (for both testing and because they look kinda cool)?
btowntincan is offline   Reply With Quote
Old 04-26-2012, 05:02 PM   #2
Kevin245's Avatar
If you have the 12 volt service functioning you can use a jumper wire in the 7-pin connector. I use a turn signal flasher in mine sometimes to make them blink.
Eleanor Roosevelt
Old 04-26-2012, 05:06 PM   #3
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
I am assuming you just connect the 12v pin and marker light pin with a wire?
1982 34' Limited
2000 Excursion V10 4x4
WBCCI #3321
TAC #GA-24
c_lewis77 is offline   Reply With Quote
Old 04-26-2012, 05:43 PM   #4
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
I recommend you go to an auto parts store or Walmart and buy a fuse link with fuse installed. You can then use it to jump the hot 12 v and marker lights female pin on the 7 pin connector. Looking at the standard (there are various setups check yours) its the 12 and 10 o'clock connector on your trailer 7 pin connector. You must be plugged in to 120v and your battery and converter must be on.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 04-26-2012, 06:52 PM   #5
pgr32e's Avatar
1974 27' Overlander
Sault ste Marie , Ontario
I ran a wire from 12v source to a fuse, then to the center pole of a single pole double throw switch ( switch has center off either side on positions.) One side goes through a flasher then to a splice with the wire from the other side of the switch, then to the connection with the running lights. Both ends were connected at the internal end of the 7 pin connector and the switch was mounted on the shelf at the front window. Switch is marked Flash Off Steady. Not only does it look neat, if you have to leave the trailer on the side of the road ( shudder ) at night it will be well lit, at least as long as the battery holds out.....Phil.
pgr32e is offline   Reply With Quote
Old 04-27-2012, 12:07 PM   #6
Wise Elder
Jammer's Avatar
2010 30' Classic
I have installed a switch inside the trailer for the purpose. It's sometimes useful to turn on the marker lights to help people who don't know where we parked find the trailer.
Old 04-27-2012, 12:15 PM   #7
All good info, i think i'll try to do it. Jammer, where did you put the switch?
Old 04-27-2012, 12:42 PM   #8
Wise Elder
Jammer's Avatar
2010 30' Classic
I put it next to the fuse panel under the gaucho. On my trailer that's where the 7-way wiring terminates, so it took minimal wiring to make it work.
Old 04-27-2012, 10:01 PM   #9
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
Worked like a champ! Thanks!
1982 34' Limited
WBCCI #3321
TAC #GA-24
Old 12-15-2012, 02:10 PM   #10
Snedwid's Avatar
2011 23' FB Flying Cloud
Perry , Florida
Somewhere, I'd seen an advertisement for a plug that goes on the trailer end of the 7 way that does this job,,, anybody know what the link is ???
"If you don't know where you are going, you will wind up somewhere else." Yogi Berra
Snedwid is offline   Reply With Quote
Old 12-15-2012, 02:19 PM   #11
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
If you install LED marker lights (and post #122 following), you can run them at reduced brightness with one additional interior switch. You can set your lights up so you run only the front markers as party lights, if you like, or any combination of front, rear, and tail.
At 25 milliamps for all five front markers, you could leave them on for a whole rally and not worry about the battery. This is a reduction of current of about 1/160th from the original markers.
Zep
Old 12-15-2012, 02:41 PM   #12
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
Snedwid try this link. I ordered two from them figuring someone at a campground would want to buy one...they did. RV Glow - Turn your outside camper lights into patio lights.
TAC PA-5
WBCCI 4871
Roadrunner is offline   Reply With Quote
Old 03-06-2017, 03:20 PM   #13
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
I just use a 5 amp fuse, ($1.50) into those two terminals.
For convenience, I soldered a piece of 14 ga. wire on each terminal of the fuse to facilitate installation.
MelGoddard is offline   Reply With Quote
Old 03-06-2017, 03:35 PM   #14
Boxite's Avatar
2008 22' Sport
It requires no wiring or creativity at all...to simply plug an ordinary fuse into the 7-way umbilical connector between the 12+ and the running lights pin. Use a small one like 3 or 5 amps max.
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
