Old 03-25-2012, 06:02 PM   #1
1974 25' Tradewind
Berryville , Virginia
Switches at door
I have there switches by the door . One works for the flood light. One switches the stair light. I have another which has three contacts. The schematic shows it operating the galley light and the fan on the range exhaust. The galley light does switch , but I have a red and white wire which does not run to the galley fan. What does this line run to?
Also why would they have put a switch on the door when the micro switch on the lever turns on the fan?
batt is offline   Reply With Quote
Old 03-25-2012, 06:09 PM   #2
Both the door switch and the original galley light switch, were three way switches.
Old 03-25-2012, 06:46 PM   #3
larry b's Avatar
1975 31' Sovereign
howell , Michigan
The one with three contacts in mine is a three way switch with the light over the kitchen sink. It to has two red with white stripe wires and one brown wire which is the hot wire.
The light over the kitchen sink also has a switch on it.
larry b is offline   Reply With Quote
Old 03-27-2012, 08:04 AM   #4
1974 25' Tradewind
Thanks for the information. So I take it it did not go to the range exhaust fan only to the galley light. Thanks
Old 10-24-2012, 07:07 PM   #5
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
Is the rocker switch on the galley wall for 12v lights above the galley? We have a "78" with no galley lights but wiring it there. Should I be looking for 12v or 110v lights? Thanks!
PA-TAC 5
WBCCI 4871
Roadrunner is offline   Reply With Quote
Switches at door batt Lights - Interior & Exterior 4 10-24-2012 07:07 PM
2006 Safari 23' with broken Dometic freezer door springs Goal15 Refrigerators 5 08-16-2012 06:17 AM
Bob Wheeler at The Motorhome, Caravan & Camping Show at London's ExCeL WK57ABF Airstream "In the News" 9 03-25-2012 04:41 PM
Went to look at AS for the first time farmerdave Buyer Guidelines 11 03-25-2012 02:04 PM
