Old 11-15-2014, 11:01 PM   #1
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Switch to LED or else.....
Hi, tonight while camping in Carlsbad, New Mexico, one of my interior dome lights was going off and on. This is the front one controlled by the door switch. This is the one used the most and left on for hours. On Safaris like mine the incandescent lights are mounted with the metal reflectors touching the vinyl headliner. These lights get very hot. I removed this light fixture to see if I could fix it or swap it with another dome lamp assembly. This light actually charred my headliner and won't go back up. I will switch to LED or else my trailer could catch fire. My trailer is ten years old, so this has lasted a long time. But now I will make a change to some, most, or all of my interior lights.
ID:	226641   Click image for larger version
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 11-16-2014, 05:19 AM   #2
Gainesville , Florida
Thanks for the heads up. Will pay more attention to mine. Jim
Old 11-16-2014, 06:27 AM   #3
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
That's good to know..... I'll check our Avion!
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 11-16-2014, 06:50 AM   #4
Retail6's Avatar
2007 28' Safari SE
Springdale , Arkansas
Amazon is your friend. Check the comments closely though. (Also go prime)
Retail6 is offline   Reply With Quote
Old 11-16-2014, 08:26 AM   #5
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
I switched to LEDs to reduce power consumption, but my 2001 Safari 25 had incandescent bulbs in it for 13 years before I owned it. I have pulled that light and the one in the bedroom area and have no discoloration of the headliner. What bulbs are you using?
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 11-16-2014, 08:39 AM   #6
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I had some heat-induced discoloration on Old Lucy's (2005 25FB) vinyl headliner under the incandescent light fixtures. I replaced the bulbs with LED's. I never did care for the light they put out. Back then, the available LED replacements were way too white for my liking.
Brian
SuEllyn & Brian McCabe
Old 11-16-2014, 08:48 AM   #7
ottawa (greely) , Ontario
WOW that's a heads up to all of us with normal bulbs ,I worked for honda as a tech for many years and had heard that when we're working on cars with the headlights on and a fender cover lying on the headlamp the plastic lense could melt, I'm sure glad I put LED bulbs in my 2015 the day I picked it up, my reason is we do a lot of boondocking to conserve battery power.����
2012 silverado ext cab 4x4 ,5.3 L , 6 speed trans,3:42 final drive,tow package standard box 6 1/2 foot . 2014 honda forza 300 scooter, #2 2015 honda crf 250 L (Dual sport)
scamp is offline   Reply With Quote
Old 11-16-2014, 09:33 AM   #8
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
My trailer is not here, so I can't check to see. But I do not think our fixtures are incandescent. They look like small florescent lights. I have always assumed that's what they are. Bob, If you get a chance, can you post a picture of the bulb?
Ken
Old 11-16-2014, 09:43 AM   #9
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
scamp: Aren't LEDs standard equipment in Airstream? I thought they switched over 100% a few years ago?
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 11-16-2014, 10:30 AM   #10
z , North Carolina
Good ?
Good question TinTin. I thought AS made the switch to LED's in 2011. If I am wrong, would an experienced AS person please advise? I would like to know.
Thanks!
Gavin
FishinHatteras is offline   Reply With Quote
Old 11-16-2014, 10:53 AM   #11
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
My overhead incandecent reading light for the barrel chair was changed out first, not bad in winter, made a good head warmer, rest of year too warm, copilot didn't object to the reflection off my head but now I have to shade the led's a they do cause her to complain that they can be seen by the person laying on couch. Maybe I can recess them by using a smaller diameter led array.
Old 11-16-2014, 03:12 PM   #12
2005 19' Safari
GLENDALE , AZ
Update to similar thread on replacing automotive incandescent bulbs with LEDs:
http://www.airforums.com/forums/f447...ml#post1541211
Old 11-16-2014, 03:38 PM   #13
Cannonball's Avatar
2014 22' FB Sport
San Antonio , Texas
Our 2014 Sport did not come with LED bulbs, except in the outside storage compartment and the step light. I changed them out very quickly, excedpt for the closet light which rarely gets turned on.
Cannonball is offline   Reply With Quote
Old 11-16-2014, 04:15 PM   #14
TinTin's Avatar
Canmore , Alberta
It could be that LED bulbs are model specific.
Bob and Nancy
LED Tow Vehicle to LED Trailer Problems murreywalker Hitches, Couplers & Balls 25 09-10-2012 03:42 PM
To LED or not to LED? SilverHoot Lights - Interior & Exterior 56 10-03-2011 12:15 PM
Clipper, Hella LED, Design Line Hella, LED Kit, Stop/turn LED masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 12-15-2010 11:03 AM
