Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 10-30-2009, 05:23 PM   #1
Profile:  1967 22' Safari
AMARILLO , Texas
switch mystery
Ref. '67 Safari. Anyone know what light or appliance the electric switch located above and just forward of the entry door turns on and off? There is no outside light. In the off position everything is ok. If the switch is turned on, the 40 amp fuse on the 12V panel blows. Every light and fan works as it should with that switch in the off position.
10brink is offline   Reply With Quote
Old 10-30-2009, 05:28 PM   #2
silverleeper's Avatar
1960 18' "Footer"
Edmonds , Washington
It controls the center florescent light. It can be tricky there is an on/off switch on the florescent light as well.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 10-30-2009, 05:46 PM   #3
AMARILLO , Texas
Do you mean the center 3way? Mine's not florecent. The bulbs are regular 1141Fs. Thanks by the way!
Old 10-30-2009, 06:02 PM   #4
1960 18' "Footer"
On my 67 there is front to back a 3-way, florescent and a 3-way. Not including the bath area. Whatever you have in that center spot is what that switch controls.
If you don't have that light the wires may have been capped. It's possible that something has come loose and touching the skin. If that switch is non-fictional then take it out, cap the wires and put a cover plate on it.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 10-30-2009, 06:21 PM   #5
AMARILLO , Texas
Well.....I have two 3ways in the "living area" and one 3 way in the bath. Nothing in between. Nothing changed, removed, or renovated in that regard.
Old 10-30-2009, 06:33 PM   #6
Lumatic's Avatar
Profile:  1971 25' Tradewind
Estancia , New Mexico
Not sure about 67s but in 70s there is a 2nd switch about where you describe so that you can turn on the galley light as you enter the trailer from the on a spooky dark night to scare the gremlins.
Pay no attention to the man behind the curtain- WoZ
Old 10-30-2009, 06:41 PM   #7
AMARILLO , Texas
Yes, I have a 3way light over the counter also. All the 3ways work on their own, but the fuse blows when you turn on the light switch. Maybe a short between the switch and the lights? Electricity never was my calling!
Old 10-30-2009, 06:53 PM   #8
1960 18' "Footer"
I'm wrong here. Had to go look. I have a three way thats over where the table is and another fixture (florescent) over the fridge area. The fridge one is the one controlled by the switch.
I also have a 3-way over the sink and a florescent under the front cabinet that shines down on the table. Its hard to see unless you look up and under.
Are we on the same page now.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 10-30-2009, 06:56 PM   #9
1960 18' "Footer"
Could be a bad switch too.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 10-30-2009, 07:23 PM   #10
AMARILLO , Texas
Looks like I don't have the same light set up that you do. I don't have any florecent lights and certainly no light over the fridge. Nothing over where the table used to be. (I changed that in the restoration) I like your idea about capping it off. Good plan!
Old 10-30-2009, 07:35 PM   #11
1960 18' "Footer"
If you get a chance post a pic or two I'd like to see your Safari.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 10-30-2009, 08:17 PM   #12
AMARILLO , Texas
I'll take a couple of pics this weekend. I'm just finishing up a two year semi-restoration (took about a year longer than I thought) and we're going to the Texas coast on Monday. This whole time I've told myself that I needed to find out what that switch goes to. I was sure it was one of the overhead lights. I've replaced all the 3way switches in them and the hot wires going to the switches were all hot, all the time. I still like your wire capping idea best. I'm still going to work on it tomorrow. Thanks again.
Old 10-30-2009, 08:41 PM   #13
Lynn
Commercial Vendor
eubank's Avatar
Profile:  1967 30' Sovereign
Angel Fire , New Mexico
We had the same mystery with our 67. The switch near the door is indeed just a second switch on the light in the kitchen. But ours also had a problem. There is one huge wad of wires that come together at the kitchen light, and the PO had miswired the wad so that the switch at the door wound up being two positives, the result of which was pretty much nil. After discovering from other owners of 67 rigs what the correct setup was supposed to be, I redid the wad of wires. And now, when we step into the rig at night, you have light with a flick of the switch near the door. (The caveat: Don't use the switch at the light in the kitchen. Just leave it on.)
Lynn
WBCCI 21043 | Blog
Monte Verde RV Park & Campground: 50% WBCCI discount
Angel Fire, New Mexico
Old 10-31-2009, 09:03 AM   #14
AMARILLO , Texas
Thanks for all the help. I'm going to tackle it again today. If I don't see a correctable problem pretty quickly, I'll just cap the wires and work on it later. I'm running out of time.
Need help with Mystery Switch in 1988 Limited Cantrell Lights - Interior & Exterior 8 12-25-2008 08:03 PM
Help With 1967 Globetrotter Mystery Switch toddster Lights - Interior & Exterior 19 12-15-2008 02:03 AM
Switch Mystery excella1976 1975-1976 Excella 500 2 01-26-2008 09:06 AM
mystery switch jagcb750 Classic Motorhomes 30 10-28-2007 08:54 PM
Mystery toggle switch mpumphrey04 Electrical - Systems, Generators, Batteries & Solar 9 12-07-2005 08:47 AM
