Old 08-19-2016, 10:32 AM   #1
1973 23' Safari
1970 27' Overlander
Boerne , Texas
Switch for clearance lights
My electrical skills are a bit lacking. My trailer is gutted so I have access to all wiring. I would like to put a switch inside to turn the clearance lights off and on when parked and not hitched up. I've read where people have turned on their clearance lights by using jumpers in the umbilical cord, but I would like to put a switch inside the trailer. I am thinking this should be easy. I believe I would just splice a wire anywhere along the circuit of the clearance lights and run it to the 12V dc distribution box and put the switch somewhere between the splice and the box. Is this correct? Would this interfere with the function of the clearance lights while towing at all?
Thank you,
Greg
Greg1410 is offline   Reply With Quote
Old 08-19-2016, 11:01 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
The best way would be to use a blocking diode to provide power to the clearance lights from two different sources. That way, when towing you're not back-feeding power to the house 12v system. The diode becomes your splice, with two inputs from house electric and umbilical, and one output to the lights.
Blocking diodes are also used when wiring supplemental lights for a toad to allow taillights, turn signals, etc to be powered by the towing vehicle's umbilical cable or by the toad's own electrical system, which is how I know about them.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 08-19-2016, 11:33 AM   #3
1973 23' Safari
1970 27' Overlander
Boerne , Texas
Thanks Protagonist - makes sense.
I googled 12V DC blocking diodes to learn more and find a source - could not really find anything - can you recommend a good source and size?
Greg
Old 08-19-2016, 11:40 AM   #4
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
As Protag has mentioned, the problem with simply adding a switch to the circuit is that the power the switch is adding to the circuit will flow to umbilical as well as the lights.
This could be a problem if the umbilical is shorted against something or plugged into the vehicle.
Another way to solve the back feed issue, instead of a blocking diode, would be to install a double throw switch.
One would install the switch inside and run the light wire from the umbilical to said switch, a power wire from the 12 volt system of the trailer, and connect the center pole to the lights.
This would allow the choice of powering the lights from the umbilical or the 12 volt system.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 08-19-2016, 11:50 AM   #5
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , WNY
Thumbs up What I did....
.......for our 63 Safari.
Got a spare female 7way plug, jumped 12v to the running light pin. Just plugged it in when we felt kool. (I suppose I could have put a switch/fuse there)
PFC
but Iím the Husband, so we went to Cleveland.
RLC
Step aside Starbucks, this is a job for alcohol.
Old 08-19-2016, 12:19 PM   #6
2000 30' Excella
Greeneville , Tennessee
Searching for a "blocking diode" is like searching for "wet water line". All diodes are blocking, that's what they do. Simply look for a diode with the appropriate power rating. As for me, I use a plug like the one on my TV and strap the running light terminal to the battery terminal. When I park, I plug it in.
jimfa440 is offline   Reply With Quote
Old 08-19-2016, 12:28 PM   #7
64airstream's Avatar
1964 22' Safari
1968 26' Overlander
Beaver County , Pennsylvania
I have not installed a switch, but I've thought about it. I have on "cool" occasions put a short piece of wire (jumper) between the 11 O'clock and 1 O'clock connectors (the one on each side of the alignment tab) of the 7 pin trailer plug. My thought was to simply permanently install the same jumper, but with a switch and with its wires run inside to wherever I wanted the switch. Since you'd want the plug disconnected from the tow vehicle when using the switch, this would not be fail-safe, like Pro's solution.
So, I just stick with the jumper, that way the plug is disconnected to get to the contacts. (At least for now, while I can still remember that I have a poor memory...)
Roy
64airstream is offline   Reply With Quote
Old 08-19-2016, 12:42 PM   #8
E Pluribus Aluminus
Jaxon's Avatar
2008 34' Classic S/O
1967 22' Safari
2005 30' Classic
Rockport , Texas
Send a message via AIM to Jaxon Send a message via Yahoo to Jaxon
Roy
Do the same thing but using a 10amp automotive fuse plugged in at the 11 & 1 oíclock positions...
Bill & Kim
WBCCI 7005 * AIR 9218
The trouble with trouble is it always starts out as fun...
Jaxon is offline   Reply With Quote
Old 08-19-2016, 12:49 PM   #9
Stay CazuaL
cazual6's Avatar
2014 19' Flying Cloud
Reseda , California
You can also check out, a double pull double throw switch. This will ensure you don't have to worry about any back feed.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
"Sweat is your fat crying"
WBCCI 9164
cazual6 is offline   Reply With Quote
Old 08-19-2016, 01:11 PM   #10
1973 23' Safari
1970 27' Overlander
Boerne , Texas
JD:
Thanks for the note - I like the switch idea.
Would this be an SPDT switch? I would splice the switch in between the umbilical and the first clearance light I assume. Also, my clearance lights are grounded where they are at - to the shell; so I assume I would not need an additional ground wire, correct? So when I am driving, the switch would allow power from the umbilical, and when when camped, I can flip the switch to turn them on. If I am disconnected from my TV and want the lights off, i would switch them back to the umbilical I assume.
Sound correct?
Greg
Old 08-19-2016, 01:21 PM   #11
jdalrymple's Avatar
Jay , Oklahoma
JD:
Sound correct?
Greg
Yes, SPDT switch.
No change to grounding, as the shell serves as the negative connection for both the 12 volt system in the trailer as well as the tow vehicle.
When parked with umbilical unplugged, the switch would simply function as an on/off as there would be no power applied via the tow vehicle.
Sounds like you see the light............
Regards,
JD
Jeff & Cindy
'91 350 LE MH
Old 08-19-2016, 01:23 PM   #12
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Well, what little I know about electricity, would be shocking. Be forewarned...
What follows is a "hold my beer and watch this" moment.
For starters, this what I would use to test the theory while the "inner walls" are accessible.
Perhaps it would be a good idea to build a "project box" which you mount the components and wiring... And place where you have access... I case of failure... This way you can add a mounted fuse for easy replacement if needed.
They may sell all those parts on the website, but here is diode link...
http://www.allelectronics.com/make-a...diode-5/1.html
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-19-2016, 06:34 PM   #13
1976 31' Sovereign
Oswego , Illinois
Putting swt. for clearance lights just 1 more thing to go wrong or forget to turn off. Just use 10 amp fuze in umbilical cord at 11 & 1 o'clock position, SAFER than SWT. and no worry of back feed or miswiring or complicated wiring. Also less than1$.
Old 08-19-2016, 06:38 PM   #14
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I am with Robert Cross. Simple and you can't forget to turn it off.
Clearance clearance LEDs mayco Classic Motorhomes 55 04-29-2016 05:41 PM
Running marker / clearance lights unhooked Kistler Electrical - Systems, Generators, Batteries & Solar 19 12-18-2006 08:30 PM
clearance lights not sealed? Cruiser Lights - Interior & Exterior 3 11-03-2003 04:23 PM
LED Clearance/Marker lights Safari Tim Lights - Interior & Exterior 13 10-24-2003 10:54 PM
Upper Identification Lights aka(Clearance Lights) pap Lights - Interior & Exterior 7 04-08-2003 07:14 PM
