Old 08-20-2016, 12:36 PM   #15
Bathurst , New Brunswick
Hi
If you have a hitch battery box, how about putting another female 7 pin socket on the hitch box. In other words ,your trailer whip will have 2 males. Then put a simple toggle next to it. When parked just flip the switch. Use an inline fuse for protection. That is the way i have set up my vintage travelux. See attached pictures. Hope this helps. Take care
ID:	269597   Click image for larger version
mrfixit51 is offline   Reply With Quote
Old 08-20-2016, 08:02 PM   #16
1979 23' Safari
Wayland , New York
If you want to use a switch it's pretty easy. Get a 12v on-on switch. They have them for rv lights etc, common at rv dealer parts departments. Also VTS has them. They have 3 prongs on back center prong is the load, in this case feeding to the running lights. The other two prongs are the suply voltage wires. In this case you would connect one to the wire from the umbilicle the other to a 12v supply from the trailer. When the switch is on one position it will power from umbilicle, switched the other way 12v from trailer. Can't be both at same time so no back feed worries.
Old 08-20-2016, 09:16 PM   #17
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Buy yourself a remote switch off ebay, and connect it to a female connector. Just connect 4 wires, plug it in and push the button.
Old 08-21-2016, 07:13 AM   #18
thanks hijoe silver, you are right . Got to protect the feedback. A 3 position is necessary.
Old 08-21-2016, 07:33 AM   #19
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
That type of switch works.
The main reason I recommended a blocking diode instead is that with the diode, you can't forget to switch on the clearance lights when you plug in the umbilical cable; they come on automatically. A blocking diode combined with a simple on/off switch only on the house side lets you choose whether to turn the clearance lights on when camping, but always have them on when the tow vehicle's lights are on.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 08-21-2016, 07:43 AM   #20
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , WNY
Thumbs up
Originally Posted by ROBERT CROSS View Post
.......for our 63 Safari.
Got a spare female 7way plug, jumped 12v to the running light pin. Just plugged it in when we felt kool. (I suppose I could have put a switch/fuse there)
FWIW......since getting the Classic I no longer feel the need to be , so the running lights only run at night while running down the road.
PFC
but I’m the Husband, so we went to Cleveland.
RLC
Step aside Starbucks, this is a job for alcohol.
Old 08-21-2016, 07:46 AM   #21
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Make certain to mount said switch outside so annoyed camper neighbors can shut off by themselves! Nobody likes glaring rv lights in a dark star filled night!
Old 08-21-2016, 08:45 AM   #22
1973 23' Safari
1970 27' Overlander
Boerne , Texas
Wow - lots of great suggestions consider. I will have to think about this for a bit. Thank you all!
Greg
Greg1410 is offline   Reply With Quote
Old 08-21-2016, 03:44 PM   #23
1973 23' Safari
1970 27' Overlander
Boerne , Texas
Thanks Protagonist. If I opt to go with a switch inside, your suggestion of doing both the blocking diode and switch makes sense to be safe. For the blocking diode - I guess I would try to find one that is for 12V and 15 amp capacity (since my wire is 14AWG)? I found this on ebay - http://www.ebay.com/bhp/schottky-blocking-diodes - but hard time finding a 12V one. Any suggestions?
Also, will I need to run a ground to the switch?
Greg
Old 08-21-2016, 03:59 PM   #24
Greg
I got the diodes for my toad at my Airstream dealer, Foley RV in Gulfport, MS. I went with the ones they suggested.
You shouldn't need to run a ground to the switch. The switch simply goes in the hot wire at the location most convenient to you; the lights still are grounded normally.
WBCCI #1105
TAC LA-4
Old 08-21-2016, 04:28 PM   #25
2007 22' International CCD
Switch for clearance lights
Any silicone rectifier or Schottky diode with a 15 amp rating at any voltage above 12 volts will work.
The voltage rating is not an issue. It's all about current when you are picking a diode for this use.
KE4GNK/AE
Clearance clearance LEDs mayco Classic Motorhomes 55 04-29-2016 05:41 PM
Running marker / clearance lights unhooked Kistler Electrical - Systems, Generators, Batteries & Solar 19 12-18-2006 08:30 PM
clearance lights not sealed? Cruiser Lights - Interior & Exterior 3 11-03-2003 04:23 PM
LED Clearance/Marker lights Safari Tim Lights - Interior & Exterior 13 10-24-2003 10:54 PM
Upper Identification Lights aka(Clearance Lights) pap Lights - Interior & Exterior 7 04-08-2003 07:14 PM
