Old 01-04-2008, 01:41 PM   #1
'67 Safari -Pocket Waffle
Adair's Avatar
1967 22' Safari
Seattle , Washington
Switch above refrigerator in 67' safari
Howdy,
67' Safari, one switch above refrigerator, another electrical box with a curious little fixture on the cover plate. I have no idea what either is for. It would be swell if it had something to do with the water pump because right now I have no continuity at the pump.
Cheers, Adair
'67 Safari 'Pocket Waffle'
"We are all born mad...some remain so."
-Beckett
Adair is offline   Reply With Quote
Old 01-04-2008, 01:54 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Your in luck
Yep! Its for the water pump. You can get the replacement pumps inexpensively on EBAY.
Old 01-04-2008, 02:00 PM   #3
Adair's Avatar
1967 22' Safari
Thanks M.R.
I have multiple back up pumps. I'm enamored with the little reciprocating guys. My pumps work fine, I just didn't have any juice. At least now I can track down the break in the line a bit more easily, or maybe it is as simple as a loose connection at the switch.
This place is great. I had an answer in five minutes.
Now what is the other deal next to the pump switch?
-A.
-Beckett
Old 01-04-2008, 03:29 PM   #4
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
My '67 Airstream had four things around that general area:
120 vac outlet
Switch for water pump
12 vdc outlet (looks like a cigarette lighter)
Television antenna outlet (three, small, triangularly-spaced, 1/8-inch D holes on a plate)
Tom
Old 01-04-2008, 09:18 PM   #5
Adair's Avatar
1967 22' Safari
Had one loose wire to the water pump switch. Now the pump is going fine.
Looked at the curious plate I was inquiring about. Pulled on the tab that projected out...and it slipped right out of its socket. The male side of this was in the wall socket; two prongs. The female side was in my hand and it had two copper sleeves. I really don't know what it is, but perhaps as TomW mentioned it was related to the TV since the shelf above the fridge seems to be popularly understood as a TV shelf.
Many thanks to you all. Tomorrow I will fill up my water tank for the first time and have pressure. Wintering in a trailer without running water has been exciting the last couple of weeks.
A.
-Beckett
Pocket door rollers for 67' Safari Adair Cabinets, Counter Tops & Furnishings 3 10-12-2007 09:23 PM
Atwood HW Heater for 67' Safari Adair Water Heaters, Filters & Pumps 13 07-13-2007 08:40 AM
73 Safari Refrigerator kneal Refrigerators 3 01-02-2007 06:08 PM
City/Battery Power Switch Broken? '63 Safari DenverAaron Electrical - Systems, Generators, Batteries & Solar 8 10-06-2006 09:32 AM
switch for 12v supply to refrigerator nickcrowhurst Refrigerators 11 02-09-2004 02:33 PM
