Old 06-12-2011, 01:19 PM   #1
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
Swap 12V LED for 110V Bulbs?
I am wondering if I can hook up a standard 110 light fixture to the existing 12 wires and then use a screw-in 12v LED bulb? If so, this would eliminate the need to fish wires from the fuse box to the light fixtures. Can it be done? Thanks!
Roadrunner is offline   Reply With Quote
Old 06-12-2011, 03:12 PM   #2
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
Yes you can. I currently have a standard light fixture running on 12 volt DC. As long as the wires are heavy enough to carry the power. going from 110 v AC to 12 v DC is easiest. If the wire can carry the higher volts with the average watts being 60 watts, then 12 v at 60 watts is a breeze. You can buy a 12 v DC bulb that screws right into a standar socket right at NAPA. Just ask for it as one is used in a 12 v lead light that attaches to the battery via clips. Take a marker & write a rminder on the inside of the fixture where the bulb goes. Otherwise you could go crazy trying to figure out why it won't work when you replace it with a regular 110 v AV bulb.
Ricky
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
12v
LED light kit for the Monarch stop tail and turn light Dan@LED4RV Commercial Listings 5 05-12-2014 05:05 AM
LED Tow Vehicle to LED Trailer Problems murreywalker Hitches, Couplers & Balls 25 09-10-2012 03:42 PM
To LED or not to LED? SilverHoot Lights - Interior & Exterior 56 10-03-2011 12:15 PM
Replacement LED fixture under front cap Pat Conway Lights - Interior & Exterior 2 04-12-2011 01:22 PM
LED replacement for '64 Auto-Lamp 7" taillight Globie64 Lights - Interior & Exterior 8 03-12-2011 07:37 PM
