Old 09-19-2015, 01:06 PM   #1
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Supernight failure
I've bragged so much about my $25 Supernight led strip, it finally failed on me.
I assumed it couldn't be the strip. The power supply was getting power (blue led on in the power pack) so I changed the battery in the remote. Still nothing. So I ordered a new remote and connector box. Still nothing. I'm assuming now the metal staples linking the 16' strip together are the problem. They look a little funky now.
Name:	ImageUploadedByAirstream Forums1442689512.265250.jpg
So I've ordered a new strip and will see if that works. Might be thinking of a plan B C and D soon...
Anyone else have issues like this?
Old 09-19-2015, 01:53 PM   #2
dennis3751's Avatar
1976 29' Ambassador
Fitchburg , Wisconsin
Those "staples" look like solder joints between strip segments. You might be able to heat them with a soldering iron to get better continuity. The part directly connected to the power supply should still light up now even if these intermediate connectors are broken/bad.
Dennis
dennis3751 is offline   Reply With Quote
Old 09-19-2015, 02:46 PM   #3
W , New England
Thanks Dennis. The good news about these lights is they're sealed in a silicone sort of tube so they're waterproof. The bad news is - working on those joints probably means throwing it out and replacing.
Oh well....it's not too expensive an experiment 😕
Marshall 250 regulator failure nickcrowhurst LP Gas, Piping, Tanks & Regulators 11 04-18-2004 07:08 AM
OPD valves... FAILURE!! Silver Bullet LP Gas, Piping, Tanks & Regulators 10 11-28-2003 08:07 AM
Followup to valve stem failure dtbw Wheels, Hubs & Bearings 0 10-29-2003 08:40 AM
Valve stem failure on '02 Bambi dtbw Wheels, Hubs & Bearings 12 10-25-2003 10:17 AM
city water inlet valve failure? JohnGalt48 Fresh Water Systems 2 08-01-2002 04:43 PM
