Old 04-05-2011, 08:34 PM   #1
NicheVintage's Avatar
1965 26' Overlander
The Gorgeous Pac Northwest , Washington
Images: 34
Street side brake light not working w/ running lights on
Our street side brake light is not working when our running lights are on. The curbside light does however. They used to work until this weekend. Any advice on how to fix it?
Thanks.
WBCCI# 2578
Four Corners Unit
Our travel and resto blog:
http://web.me.com/tiffanydanley
NicheVintage is offline   Reply With Quote
Old 04-05-2011, 10:43 PM   #2
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
I take it the brake light works when the running lights are not on?
4RXLA is offline   Reply With Quote
Old 04-05-2011, 10:51 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Check connections.
First; I'm assuming you have checked the bulb. Next; Clean the contacts on your 7 pin plug. Try wiggling the 7 pin pin and see if you can get the light to work. You can test it by turning on the turn signal, it uses the same filament in the bulb as the brake light. Also clean the bulb base if it looks good, both the contacts and the brass base, also clean the socket. If this doesn't work, it's time to get the meter out.
TG Twinkie is online now   Reply With Quote
Old 04-06-2011, 09:01 AM   #4
extiger's Avatar
2011 30' Classic
Kingwood , Texas
You may also want to check the TV fuses. Had a similar problem and after checking bulbs, cleaning contacts, testing connections several times, I checked the TV fuses and found one that was blown.
extiger is offline   Reply With Quote
Old 04-06-2011, 09:09 AM   #5
dznf0g's Avatar
Oswego , Illinois
If I understand your situation correctly, I believe you may find a bad ground, and or corrosion, on that bulb socket. I believe your brake light filement is trying to get it's ground through the running light circuit. When the running lights are on you then have 12V on both sides of the brake light filement and thus no current flow and no light.
Old 04-06-2011, 10:00 AM   #6
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
The quickest thing to check is the previously mentioned brake light/turn signal fuse in the tow vehicle. Most modern TV's that came with factory installed tow packages have separate circuits for the trailer lighting.
Check this first as it is the easiest to diagnose and correct.
Brian
SuEllyn & Brian McCabe
moosetags is online now   Reply With Quote
Old 04-06-2011, 10:25 AM   #7
dznf0g's Avatar
Oswego , Illinois
To clarify.....you have brake lights with running lights off and no streeside brake light when running lights are on, right?
That eliminates fuse and power supply issues, I believe.
Old 08-23-2011, 05:54 AM   #8
71safari's Avatar
1971 23' Safari
Waterloo , Ontario
Images: 16
Our 1971 Safari has a similair issue - when the running lights are on the signal lights don't work, when the running lights are off the signal lights work. We have limited ourselves to daytime towing... any advice appreciated.
Finally found a great deal on an Airstream. Trailer is in good shape, just a few things we need to fix up & want to modify. We plan to make our 'vintage' look like the newer Airstreams.
71safari is offline   Reply With Quote
Keeping running lights on while camping RichHog Lights - Interior & Exterior 45 07-25-2017 02:16 PM
Side running lights GeocamperAS Lights - Interior & Exterior 4 03-13-2011 09:15 PM
Right brake light outage, mystery solved. DaveFL General Motorhome Topics 1 02-21-2011 12:26 PM
Running Lights LED - How do I route the wire? AirHome Lights - Interior & Exterior 6 02-20-2011 07:15 PM
Lens removal for orange running lights on 1973 model AirHome Lights - Interior & Exterior 6 02-07-2011 09:42 PM
