Old 07-30-2014, 10:03 PM   #1
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Step / porch light
1999 34' Excella.
I can't figure out how to remove the assembly from side of the AS without damaging something...
It appears I will need a new one to replace it with once removed.
I look forward to your advice.
"Thanks" in advance!
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-31-2014, 04:32 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Bump
Channing
WBCCI# 30676
Old 07-31-2014, 07:49 PM   #3
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
CW,
Got a picture of the light in question?
Lance
Top is offline   Reply With Quote
Old 07-31-2014, 10:24 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Yes, Top...sorry it turned sideways. The left is the upside in the pic
Channing
WBCCI# 30676
Old 08-01-2014, 05:09 AM   #5
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
OK, I see now. I think those are referred to as "docking" lights or "courtesy" lights.
Tape around it with two layers of blue or green painter's tape to protect the skin from when a tool slips. (it happens) Then take the screws out, use a plastic razor blade or other pointed plastic tool to cut the sealant and separate the light from the skin. If it is very tough, heat it with a heat gun or hold a rag soaked with mineral spirits over it for a while to soften the sealant. If the sealant is Acryl-R or Parbond, mineral spirits won't work very well.
Easy peasy.
Lance
Old 08-01-2014, 06:17 AM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Thanks Top!
Channing
WBCCI# 30676
Old 08-01-2014, 06:32 AM   #7
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Heat gun and mineral spirits NOT at the same time.
Old 08-01-2014, 08:23 AM   #8
bganso's Avatar
1994 30' Excella
Truckee , California
Is there a reason to remove it? I was going to change mine too, but decided it was easier to buy a new cover and upgrade the bulb to LED. The minimal heat from the LED will prevent the lens cover from yellowing and melting.
bganso is offline   Reply With Quote
Old 08-01-2014, 08:29 AM   #9
dznf0g's Avatar
Oswego , Illinois
I installed an LED bulb in the existing lamp housing.
-Rich-
Old 08-07-2014, 05:33 AM   #10
Skater's Avatar
1995 30' Excella
Bowie , Maryland
I did the LED thing, too, using one of these I think. It works perfectly, throwing far more light where we need it than I expected.
Of course the OP might be replacing it because the fixture is bad, or something like that... an LED won't help with that problem.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 08-07-2014, 07:17 AM   #11
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
The fixture is still "serviceable"... For now. I was going to replace because there is some corrosion which is why I sealed around it... To get more time before replacing. I cleaned out the socket...replaced bulb last year.
I need to get another lens/cover and LED before proceeding.
Thanks!
Channing
WBCCI# 30676
Old 05-10-2016, 10:55 AM   #12
1991 25' Excella
Hartford , Wisconsin
Where can I get replacement lens covers for theses lights?
TOPORANGER is offline   Reply With Quote
Old 05-10-2016, 03:32 PM   #13
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
I don't have the info with me, but when I can get to my PC, I'll get it for you.
Meanwhile, you might check vintagetrailersupply.com
PaulnGina
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
"I don't mean to sound degrading but with a face like that you got nothing to laugh about" Rod Stewart (Faces)
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
PaulnGina is offline   Reply With Quote
Old 05-10-2016, 03:57 PM   #14
PaulnGina's Avatar
Good Ol' , USA
Here it is:
https://groups.yahoo.com/neo/groups/...messages/24974
PaulnGina
1987 Avion 34W
1987 Avion 34W
'Porch' Light Replacement Fixture with 1141 Bulb AirConditioner Electrical - Systems, Generators, Batteries & Solar 4 09-10-2015 11:56 PM
Porch light cleaning GlenCoombe Lights - Interior & Exterior 10 06-30-2013 02:16 PM
Porch light plug recepticle. FreshAir Lights - Interior & Exterior 33 04-27-2007 07:58 PM
Porch light only on Battery power???? campngirl Batteries, Univolts, Converters & Inverters 11 10-21-2006 06:55 AM
The $8 Porch Light Silverfly 1960 - 1964 Overlander 2 09-21-2004 06:25 PM
