07-30-2014, 10:03 PM
1999 34' Excella
Hillsboro
Step / porch light
1999 34' Excella.
I can't figure out how to remove the assembly from side of the AS without damaging something...
It appears I will need a new one to replace it with once removed.
I look forward to your advice.
"Thanks" in advance!
Peace and Blessings..
Channing
WBCCI# 30676
07-31-2014, 04:32 PM
1999 34' Excella
Hillsboro
Bump
Channing
WBCCI# 30676
07-31-2014, 07:49 PM
Always learning
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central
CW,
Got a picture of the light in question?
Lance
07-31-2014, 10:24 PM
1999 34' Excella
Hillsboro
Yes, Top...sorry it turned sideways. The left is the upside in the pic
Channing
WBCCI# 30676
08-01-2014, 05:09 AM
Always learning
1972 29' Ambassador
Central
OK, I see now. I think those are referred to as "docking" lights or "courtesy" lights.
Tape around it with two layers of blue or green painter's tape to protect the skin from when a tool slips. (it happens) Then take the screws out, use a plastic razor blade or other pointed plastic tool to cut the sealant and separate the light from the skin. If it is very tough, heat it with a heat gun or hold a rag soaked with mineral spirits over it for a while to soften the sealant. If the sealant is Acryl-R or Parbond, mineral spirits won't work very well.
Easy peasy.
Lance
08-01-2014, 06:17 AM
1999 34' Excella
Hillsboro
Thanks Top!
Channing
WBCCI# 30676
08-01-2014, 06:32 AM
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View
Heat gun and mineral spirits NOT at the same time.
08-01-2014, 08:23 AM
1994 30' Excella
Truckee
Is there a reason to remove it? I was going to change mine too, but decided it was easier to buy a new cover and upgrade the bulb to LED. The minimal heat from the LED will prevent the lens cover from yellowing and melting.
08-01-2014, 08:29 AM
Oswego
I installed an LED bulb in the existing lamp housing.
-Rich-
08-07-2014, 05:33 AM
1995 30' Excella
Bowie
, Maryland
I did the LED thing, too, using one of these I think. It works perfectly, throwing far more light where we need it than I expected.
Of course the OP might be replacing it because the fixture is bad, or something like that... an LED won't help with that problem.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
08-07-2014, 07:17 AM
1999 34' Excella
Hillsboro
The fixture is still "serviceable"... For now. I was going to replace because there is some corrosion which is why I sealed around it... To get more time before replacing. I cleaned out the socket...replaced bulb last year.
I need to get another lens/cover and LED before proceeding.
Thanks!
Channing
WBCCI# 30676
05-10-2016, 10:55 AM
1991 25' Excella
Sioux Falls
, South Dakota
Where can I get replacement lens covers for theses lights?
05-10-2016, 03:32 PM
1987 Avion 34W owner
Good Ol'
, USA
I don't have the info with me, but when I can get to my PC, I'll get it for you.
Meanwhile, you might check vintagetrailersupply.com
PaulnGina
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
"I don't mean to sound degrading but with a face like that you got nothing to laugh about" Rod Stewart (Faces)
I this great country!!!!
1987 Avion 34W
05-10-2016, 03:57 PM
Good Ol'
, USA
Here it is:
https://groups.yahoo.com/neo/groups/...messages/24974
PaulnGina
1987 Avion 34W
1987 Avion 34W
05-10-2016, 04:07 PM
Good Ol'
, USA
Here's the direct link for just the lens
http://www.rvautoparts.com/Fastners-...28_p_7974.html
And for the entire fixture:
http://www.rvautoparts.com/Fastners-...27_p_7975.html
PaulnGina
1987 Avion 34W
1987 Avion 34W
05-26-2016, 11:20 AM
1991 25' Excella
Sioux Falls
, South Dakota
Thank You
Originally Posted by PaulnGina
Thanks for the lead on where to purchase the lens. I ordered 2 from them, total $19.13 including mailing.
