Old 11-12-2019, 02:56 PM   #1
2007 25' Safari
Richmond , British Columbia
"Spring" clips for interior light fixture
Hi there,
Just joined this forum, as I just bought a used Airstream which needs a bit of work... first task is fixing one of the interior light fixtures which is dangling because the 2 spring clips/wings have busted... do I need to find/buy an entire new fixture or does anyone know if I can simply replace the spring clips somehow?!
Thanks in advance!
JTvancity is offline   Reply With Quote
Old 11-12-2019, 03:59 PM   #2
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
not sure what/which light you mean - picture would be helpful
La Dolce Vita Brick & Mona
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD SuperCrew FX4 Lariart (MaxTow) "Red Dragon"
Married With Airstream Blog Click Here
Blog Languages: English/French/Spanish
drbrick is offline   Reply With Quote
Old 11-12-2019, 04:06 PM   #3
Kensington , Maryland
Originally Posted by JTvancity View Post
Hi there,
Thanks in advance!
JT I've been down that road. Those springs are no fun to work with.
You may consider making your own replacement or you could bite the bullet and order a new fixture from:
https://www.itc-rv.com/product-categ...head-lighting/
2017 25' FC FB "Buck"
Subforum dedicated to Airstreams and riding bicycles:
https://www.velocipedesalon.com/forum/f62/
Too tall is offline   Reply With Quote
Old 11-12-2019, 11:52 PM   #4
Burnside Bob's Avatar
2009 25' FB Flying Cloud
1973 31' Sovereign
Mt Angel , Oregon
If you are talking about the recessed ceiling lights that are about 2 1/4 inch diameter, they were made by Decor. The same style light is still used, although it now comes in LED. The springs are not available by themselves.
That said, I was able to get two springs from my local Airstream dealer. The service department was returning a light that didn't work and they gave me the springs from it no charge.
So that's worth an ask, especially if you will be buying other parts as you restore your trailer.
If you opt to outright replace the lights, LED4RV is a source that is cheaper than Airstream. LED4RV also sells LEDs for these lights so you can convert to LED without replacing the fixture if you want.
Burnside
Best, Burnside
"To err is human, to air is devine."
Burnside Bob is offline   Reply With Quote
Old 11-13-2019, 03:05 PM   #5
Murfreesboro , Tennessee
I had one that the spring broke in the ceiling over the stove. Had some two sided tape that I was able tor trim around the edge of the light and peeled off the cack and stuck it back up and it has been 15,000 miles and hasn't moved. You cannot tell its there.
dnsapp is offline   Reply With Quote
Old 11-13-2019, 03:10 PM   #6
2020 27' International
Miami , Florida
I probably have the light you need if you tell me the diameter of the cut out. Only $20.
Janis33133 is offline   Reply With Quote
Old 11-20-2019, 08:35 AM   #7
Dan@LED4RV's Avatar
Denton , North Carolina
how to install the clip
Hi there,
Thanks in advance!
I do have a few of those clips
http://trvparts.com/catalog/index.ph...oducts_id=1394
That is only half the battle. Once in hand the spring is almost like a rubits cube. Here is a video that shows how
https://www.facebook.com/LED4RV/vide...3168444731418/
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Snap spring for light fixture bracket harrisona Lights - Interior & Exterior 0 09-25-2018 04:31 PM
replacing 12v fixture with LED fixture funkill Lights - Interior & Exterior 2 08-26-2009 11:20 AM
Vintage Light Fixture Light Diffusers flyfshr Lights - Interior & Exterior 5 08-21-2008 07:26 PM
60 Pacer Interior Overhead Light fixture dinky twinky Electrical - Systems, Generators, Batteries & Solar 2 03-08-2006 03:17 PM
