Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 06-08-2004, 01:27 PM   #1
DPeakMD
DPeakMD's Avatar
Profile:  1975 23' Safari
1978 31' Excella 500
Franklin , Indiana
Source for '74-'78 Tail Lights
The rectangular stop/turn/tail/reverse lights on my '78 were in very poor shape. The plastic was dull, crazed and cracked and broken in several places, especially where the screws hold them in. I found a replacement source. There's a Grote RV tail light assembly that is the exact duplicate in terms of lenses and cans to hold the lights. Obviously, the frame is unique to Airstream, but you can salvage the remaining parts. They unfortunately do not include gaskets. I had to make those myself from a gasket kit, but it turned out very nicely. I'll post some pics below of the setup. The part # for the Grote kit is: 51102. It contains all three lenses, cans, and lamps that we'd need for about $20 per side. You even can re-use the screws that come with the kit if yours are rusty like mine were! While you're in there, make sure the fiber-optic connects are pushed on all the way so you can see that the bulbs are lit in the tattle-tale indicator on the side of the trailer.
Name:	Old Tail Light.JPG
ID:	7103  Click image for larger version
Name:	New Tail Lights.jpg
Dallas
WBCCI/VAC #8481
AIR #9
W9CDC
DPeakMD is offline   Reply With Quote
Old 06-08-2004, 08:16 PM   #2
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
All of those tail light lenses and cans, are available from some Airstream dealers.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Autolamp Tail Lights? 66Overlander Electrical - Systems, Generators, Batteries & Solar 8 04-20-2004 05:54 PM
Wiring tail & running lights JimC Electrical - Systems, Generators, Batteries & Solar 4 04-14-2003 01:38 PM
Tail Lights Stopped Working dpope 2003 Safari 8 04-05-2003 01:22 PM
Broken wiring in tail lights Argosy74 Electrical - Systems, Generators, Batteries & Solar 4 10-23-2002 10:09 PM
Tail lights Chuck Electrical - Systems, Generators, Batteries & Solar 0 07-08-2002 02:58 PM
