Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 10-11-2007, 01:12 AM   #1
SilvrSausage
Streamline Imperial
SilvrSausage's Avatar
Profile:  Currently Looking...
Bellflower , California
Cool Solution for intermittent short- light bulb as ballast resistor.
On a recent trip, I had a problem with an intermittent short in the running light circuit that I could not find, and needed to drive home in the dark. Running short on fuses, I hit upon an elegant solution: I wired a 21 watt brake light bulb in series at the umbilical connector. With the filament not glowing, the resistance is very low, and the LED tail lights and low wattage side lights ran near full brightness. As I bounced along the road and the short would occur, instead of blowing yet another fuse, the light on the tongue would glow, causing its resistance to increase so that the lights winked out but the fuse didn't blow; when the circuit un-shorted, the bulb on the toungue would go out, and the running lights would be back. A light bulb in series with a circuit works as a ballast resistor, meaning it increases its resistance with higher load. The wattage of the ballast bulb must be somewhat higher than the sum of all the lights in that circuit to allow close to normal voltage to the light when the short is not present.
This is more protective to the wiring than a circuit breaker, which allows full current until it cycles off. On a trailer circuit with long wire runs, there is a greater risk that the wires could get dangerously hot without cycling the breaker. This is especially true with higher amperage circuit breakers; cars come in to my repair shop all the time with too-big circuit breakers and melty-looking (but not burnt) wires.
I thought I'd pass it along, as it may help someone else out of a bind.
-SilvrSausage
It seems I love the mountains and deserts more than my friends do. I sure miss them!
1971 Streamline Imperial project "Silver Snausage", 1985 Coleman tent trailer, 1964 Little Dipper, 1975 Northwest "Proto Toyhauler", 2004 Harbor Freight folding, still seeking my Airstream.
SilvrSausage is offline   Reply With Quote
Old 10-11-2007, 07:57 AM   #2
87MH
87MH's Avatar
Profile:  1978 31' Sovereign
Katy (West Planet Houston) , Texas
Images: 153
When in a bind you gotta' do what you gotta' do.
What a great post! I would never have thought of that.
Did you use an 1156 bulb or one of the newer "wire prong" lights?
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign Photos:'78 Sovereign Rebuild
Motorhome '87 Classic Motorhome Saga
Old 10-11-2007, 08:35 AM   #3
HiHoAgRV
Profile:  1977 29' Ambassador
Brandon , Mississippi
Images: 26
Now that was a moment of 'enlightenment'
I'll store that one in my bag of get home tricks. The closest I've come to that one was using a spare 12v battery to light one tail light after removing it from the circuit.
Hi Ho Silver RV!
Vernon, Sarah, Mac the Border Collie and-
'Epiphany' the 29' Airstream
Old 10-11-2007, 04:14 PM   #4
SilvrSausage
Streamline Imperial
Thumbs up
87, I used what I had, which was an 1156 bulb robbed from the backup light of my TV, plus the bulb holder which allowed me to use the spade connectors and wire in my toolbox. A 3157 or other wire type would have made the repair that much quicker. Any port in a storm, though, eh?
HiHo, I was fixin' to do just that with my loose deep cycle battery when I had that "flash" of inspiration. Thinking about it, it might have resulted in a fire after all, because I didn't have a fuseholder along. Either that, or it would have tipped in the trailer.
Regards,
-Silvrsausage
Intermittent 12v elec problem & solution ole81 General Interior Topics 4 07-29-2007 11:01 AM
What type of light bulb for oven? kimbal88 General Appliance Topics 1 04-10-2007 09:16 AM
How many Airstreamers does it take to change a light bulb? Foiled Again Off Topic Forum 4 10-05-2005 11:37 PM
light bulb 66 Tradewind Electrical - Systems, Generators, Batteries & Solar 2 11-08-2004 06:18 PM
Closet light bulb Tarheel Electrical - Systems, Generators, Batteries & Solar 3 07-26-2004 03:04 PM
