Old 06-12-2010, 06:16 AM   #1
2vets's Avatar
1960 24' Tradewind
St. Albans , Vermont
Side marker and clearance lighting 1960 tradewind
Trying to decide what to do with the clearance lighting on my 1960 Tradewind. The clearance lights are not original but if I remove them I have to cover the drilled holes.... should I just replace them with new clearance lights? They work but you can clearly see water inside of them and they are badly corroded. Any ideas would be appreciated!
ID:	104669   Click image for larger version
2vets is offline   Reply With Quote
Old 06-12-2010, 06:49 AM   #2
You can replace the clearance lights with the new style LED lights, that do not have a water problem.
The teardrop lights you have on the sides of the trailer, are original.
The lights above the front and rear windows, are add on's by someone. That shape light has never been used by Airstream.
Old 06-12-2010, 09:20 AM   #3
safari62's Avatar
1962 22' Safari
1957 22' Custom
1963 16' Bambi
Vacationland , Maine
Images: 43
Hi Vets
As Andy mentioned, the lower side marker lights were the original style and shape used on your trailer and I think they look best with this vintage.
Vintage Trailer Supply - Vintage travel trailer parts and supplies!
They used to have a steel base plate and would rust. The replacements are aluminum and although lightweight, they are flexible and bend to the contour of the trailer.
They can feel a bit too light weight and cheap in your hand but somehow they have survived as replacement on our trailer for the last 80/k miles. The little plastic lens attached by a tiny screw without a gasket protect the blub somehow. I had to replace four lens two years ago after a freak hail storm cracked them.
Name:	Jam 009 - Copy.jpg
safari62 is offline   Reply With Quote
Old 06-12-2010, 11:43 AM   #4
2vets's Avatar
1960 24' Tradewind
Wow.... what a fantastic photo! The teardrop lights look great up there! Thank you!
Old 06-12-2010, 11:44 AM   #5
2vets's Avatar
1960 24' Tradewind
safari62 .. How did you get rid of your ghost WBCCI numbers?
Old 06-12-2010, 01:05 PM   #6
safari62's Avatar
1962 22' Safari
1957 22' Custom
1963 16' Bambi
Images: 43
Jestco Products Buffing Supply - Airstream Polishing Kit (for lengths over 24 foot) (Powered by CubeCart)
I started off with Nuvite products and still use them, but discovered the Jestco products while helping a friend with his trailer. The abrasive material in the solid bars along with the buffer wheel used at a higher speed works well on rough areas.
Then remove all the straight cut lines with a compounder and nuvite products. Finish with the dual cyclo and S grade polish.
Colin Hyde has been testing a different product (Colin's Secret Sauce!) and claims it is a time saver. But by the time he introduces it we will all be camping in Heavens Trailer Park I fear.
1960, 1960 tradewind
Replace Marker / Clearance Lights On '87 Excella DEITZ645 Lights - Interior & Exterior 18 01-21-2008 05:24 PM
Clearance / Marker Lamp Question Number99 Lights - Interior & Exterior 5 01-04-2007 04:52 PM
Running marker / clearance lights unhooked Kistler Electrical - Systems, Generators, Batteries & Solar 19 12-18-2006 07:30 PM
Lighting up the Marker and tail lights for show startrekker2001 Electrical - Systems, Generators, Batteries & Solar 9 06-01-2006 06:36 AM
LED Clearance/Marker lights Safari Tim Lights - Interior & Exterior 13 10-24-2003 09:54 PM
