Old 10-12-2010, 09:13 PM   #1
Newberry , Florida
Short in '73 Overlander
There are three overhead lights in my '73 Overlander (27'). The center light, in the kitchen is not working. There is a blown fuse at the fuse panel, however, any replacements just blow instantly. There are four wire controlling the 12V lights and accessories. Of these four, the pink wire is popping the fuses. Any electical diagrams out there or can someone tell me what all runs off of this pink wire so I can begin a search for the short. Thanks
Overlander is offline   Reply With Quote
Old 10-12-2010, 09:20 PM   #2
x
XXXX , XXXX
Hi overlander is your as a center bath or rear bath? It makes adifference what is on that circuit.
wasagachris is offline   Reply With Quote
Old 10-12-2010, 09:25 PM   #3
x
XXXX , XXXX
Sorry it doesn't matter. The first on the circuit is roadside bed shelf light or a vanity light depending on twin or double bed layout. Next is the roadside 12V outlet in the bedroom. Then the light in the oven. Next is the overhead ceiling light in the kitchen. Last in that circuit is the power to the furnace.
Old 10-13-2010, 01:09 PM   #4
Newberry , Florida
It's a rear bath layout with double beds (one on each side of walk through). The shelf lights above each bed is working now, with the fuse pulled on the kitchen light circuit. They must run off of one of the other three. Also, this layout does not have a 12V power source in the bedroom. The furnace is a good lead though. Had problems with the water tank falling out...maybe snatched a wire loose or something since it's in the same area.
Old 10-13-2010, 02:41 PM   #5
drag'nwagon's Avatar
1970 23' Safari
1956 26' Cruiser Overlander
Lambertville , Michigan
Check the light switches them selves. I had one short out internally and it kept blowing the fuse also.
Dave
TAC# MI-1
Operation "Save Rudy" Strike Team (charter member)
Yes, I am still working on it.
drag'nwagon is offline   Reply With Quote
Short gowyn Brakes & Brake Controllers 14 02-12-2008 06:13 PM
Short -Short Ramp Lights - Interior & Exterior 0 09-12-2007 04:34 PM
I'm a little short, can u help? Shorty Electrical - Systems, Generators, Batteries & Solar 1 05-28-2006 12:46 PM
The Short, Short Trailer - Spamboree flamingo-kid1 On The Road... 2 04-14-2005 01:41 PM
12 v short Don McKelvay Electrical - Systems, Generators, Batteries & Solar 8 10-25-2003 11:44 PM
