Old 08-24-2012, 03:08 PM   #1
Re-Pete's Avatar
1992 29' Excella
Virginia Beach , Virginia
Seeking Advice on Properly Sealing Replacement Marker Lights
I'm replacing most of my red and amber marker lights. What is the best way to seal the new lights to the body of the trailer?
Pete
Pete
Virginia Beach, VA
1992 29' Excella Classic
TV 2006 Dodge Ram 2500 Mega Cab Diesel 4x4
Re-Pete is offline   Reply With Quote
Old 08-24-2012, 03:38 PM   #2
colberjs's Avatar
1964 30' Sovereign
Porum , Oklahoma
I'd like to know also.
colberjs is offline   Reply With Quote
Old 08-24-2012, 04:08 PM   #3
Baltimore , Maryland
trempro 626
Old 08-24-2012, 04:49 PM   #4
1977 Argosy 24
Milltown , Wisconsin
What is the difference between Tempro 626 & 635.
ventport is offline   Reply With Quote
Old 08-24-2012, 05:00 PM   #5
colberjs's Avatar
1964 30' Sovereign
Porum , Oklahoma
Or vulkem?
Old 08-24-2012, 05:01 PM   #6
colberjs's Avatar
1964 30' Sovereign
Porum , Oklahoma
Oops. Repost.
Old 08-24-2012, 05:12 PM   #7
Re-Pete's Avatar
1992 29' Excella
Originally Posted by 62overlander View Post
trempro 626
Thank you Frank.
For anyone who's interested here is a link to an Airstream List post I found thanks to Franks Post.
Just not sure who sells it.
Pete
Virginia Beach, VA
Old 08-24-2012, 06:11 PM   #8
626 is "texturized" It has a thicker body and longer cure time. It takes 24- 36 hours to skin over and a life time before it gets hard. I just ordered a fresh case from Fastenal this morning.
Old 08-24-2012, 06:13 PM   #9
dznf0g's Avatar
Oswego , Illinois
If they fit nicely to the curvature of the skin (1/16" or so), I prefer Parr Bond.
-Rich-
Old 08-24-2012, 08:08 PM   #10
Dan and Liz's Avatar
1987 25' Sovereign
Fort Collins , Colorado
I cut gaskets from 1/4" thick black closed cell rubber foam ordered through Ace. Conforms to shell, no adhesive or caulk needed.
Dan & Liz H
"I'd rather be happy for just one day than miserable for the rest of my life."
Dan and Liz is offline   Reply With Quote
Old 08-24-2012, 08:34 PM   #11
Central , Mississippi
I dry fit the new lamps using #6 stainless sheetmetal screws loosely fitted. I then tape the perimeter 1/16" away with blue painters tape.
I then remove the screws, apply Tempro to the back of the lamp and then install it. I use the screws instead of rivets sometimes. The tempro will squish out and the blue tape will catch it. let it set for a bit then clean the excess with mineral spirits. Finally, remove the tape.
I also leave a small gap in the sealant at the bottom of the lamp.
It works for me...your milage may vary
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 08-24-2012, 08:41 PM   #12
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I agree, good product. We first tried it a few years ago after having it recommended by Oasis RV in Tucson, long-time Airstream repair shop. There is a learning curve to apply it neatly because it is extremely sticky, but works and lasts.
doug k
Old 08-24-2012, 10:29 PM   #13
2006 22' International CCD
2007 Base Camp
Elk Valley , British Columbia
I use silicone... aluminum compatible. Everyone here screams... but it is so easy to apply, so easy to clean up, and GE's new stuff is water ready in 4 hours.
I tried lots of other stuff... wasn't until a got my silcone into every tiny crack that I didn't have any more leaks... Looks really nice... smooth and shiny like aluminum!
Friday is offline   Reply With Quote
Old 08-25-2012, 09:12 AM   #14
Re-Pete's Avatar
1992 29' Excella
Many good ideas. Thanks. Pete
Pete
Virginia Beach, VA
