Old 02-19-2015, 07:34 AM   #1
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Sealing tail lights cans on 74 Ambassador
Hey everyone
I'm looking for tips on sealing up the tail light cans on a 74 Ambassador. Should I seal? Should I use Trempro or a butyl tape?
Mike
desertair27 is offline   Reply With Quote
Old 02-19-2015, 08:12 AM   #2
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
The cans are riveted to the cast housing, right? Did you get new machined aluminum cans from VTS?
Lance
Top is offline   Reply With Quote
Old 02-19-2015, 08:40 AM   #3
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
My cans thread into the housing. All original stuff.
Here's what I have,doesn't look like any sealant was every used.
Old 02-19-2015, 10:30 AM   #4
maccamper's Avatar
1974 29' Ambassador
1966 20' Globetrotter
Central , Illinois
One approach
If I remember correctly, there was a felt gasket between the lens and can, that was the only method used to prevent water penetration. It did not work very well. We had so much trouble with the corroded lens sockets when we got the trailer that we gave up and put LED lenses in place of the originals. We put a separate, single LED in front of the fiber optic cable to retain the functionality of the indicator light on the side of the trailer.
Laird
maccamper is offline   Reply With Quote
Old 02-19-2015, 11:07 AM   #5
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
That's good info, I need to address the lens to can and the can to housing seal. The felt seal didn't work to well that's for sure.
Old 02-19-2015, 12:18 PM   #6
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Mike,
Go to a truck stop or truck and trailer place and get Truck-Lite part number 9021 (red) and 9021W (clear). This is a kit that has the lens, foam gasket and new screws.
Some butyl between the can and housing is a good idea. If you use a sealant, you'll never get the can out again without ruining the can.
Lance
Old 02-19-2015, 12:49 PM   #7
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
VTS also sells the lenses from Truck-Lite.
4-1/8" Round Lens
Lance
Old 02-19-2015, 07:01 PM   #8
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Good call Lance, thanks for the help.
Mike
Tail Lights (w/cans) cdmagda Airstream Classifieds 0 10-24-2013 01:45 PM
Round Taillight Cans Available Ganglin Lights - Interior & Exterior 5 01-08-2013 11:04 PM
Allison questions / how many cans of worms can a 28' motorhome hold Dean Rawson Mechanics Corner - Engines, Transmission & More... 55 10-03-2012 02:35 PM
Resourceful Replacement for '70s Tail Light Cans mello mike Lights - Interior & Exterior 32 09-23-2012 09:14 PM
Spray cans, brush, or roller? CMSmith General Repair Forum 7 07-24-2012 02:21 PM
