Old 08-13-2014, 10:01 AM   #1
1967 30' Sovereign
Dublin , Ohio
Sealing a new Scare Light?
I'm going to be replacing the scare light on my 1967 Sovereign and wondered if I'll need any sealants to keep it water tight.
Any advice appreciated, thanks.
jamesanyc is offline   Reply With Quote
Old 08-13-2014, 10:33 AM   #2
Rhino33's Avatar
1980 31' International
Cincinnati , Ohio
When we replaced the lens on our scarelight, it was accompanied with the sealing gasket. Unscrewed the original melted one, cleaned out the fixture and popped the new one back on. It is amazing how much this little light will illuminate!!
Jenn & Robb & our two furry kids
Maizie ('the Black Dog') & Dex ('the Brown Dog')
1980 International 31
WBCCI #4447
AIR #70157
Rhino33 is offline   Reply With Quote
Old 08-13-2014, 11:29 AM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I put a sealed LED replacement in mine. It also came with a rubber gasket.
MICHAEL
Old 08-15-2014, 01:26 PM   #4
1967 30' Sovereign
Dublin , Ohio
Thanks for the feedback. My new scare light comes with a gasket too. Was just wondering if it will do the job by itself, or whether there was a "trick" for the long-haul such as adding a touch of vulkem to something.
Old 08-15-2014, 02:49 PM   #5
AWCHIEF's Avatar
Images: 33
No leaks on mine as far as I can tell. Have had a couple of good rains.
MICHAEL
Old 08-15-2014, 06:22 PM   #6
richw46's Avatar
Lexington , Kentucky
Melted? Our scare light works but the wife noted that it appeared that it was odd shaped, like it had melted. I thought it was normal but maybe not???
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 08-19-2014, 05:22 AM   #7
Rhino33's Avatar
Cincinnati , Ohio
Hmmm - maybe you are right. I agree they are just odd shaped. Thanks~
WBCCI #4447
AIR #70157
Old 08-19-2014, 03:31 PM   #8
AWCHIEF's Avatar
Images: 33
They are a little odd shaped and the plastic lens will burn and melt using the stock 1141 bulbs. On both my Airstreams I replaced the OEM light with sealed LED glass lenses.
MICHAEL
Old 08-21-2014, 07:37 AM   #9
richw46's Avatar
Ours is still working and doesn't seem to be burned. The wife commented that it seemed to have a somewhat melted look about it. We haven't had the trailer very long and use the light only when one of us heads to the facilities. I use my trusty Coleman Dual Fuel lantern to light up the campsite.
If it goes bad I'll swap it out for the LED light.
-Rich
Rich & Yvonne
2004 4Runner SE
Old 08-21-2014, 08:11 AM   #10
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
If it were me, I would add a little sealant. The scare light on my 2005 has a thin bead around it that was done at the factory.
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Scare light and Overdoor light don't work WorkofArt Lights - Interior & Exterior 15 03-05-2014 09:41 PM
Clear Backup/Scare Light Lense Pick Lights - Interior & Exterior 0 01-17-2009 01:12 PM
Really Big Scare Light Ganglin Off Topic Forum 9 05-03-2007 06:54 PM
Replace Scare light Zeppelinium Lights - Interior & Exterior 9 03-29-2007 04:32 PM
Scare light and marker light won't work??? shinybean Lights - Interior & Exterior 12 02-12-2007 08:51 PM
