Old 07-18-2011, 10:28 AM   #1
tinbender's Avatar
2001 16' Bambi
2013 23' International
Piedmont Region , North Carolina
Sealant for Running Light Connector??
Looking for a sealant or whatever will work to ensure that wires are tight in connector. This involves the main connection point for all the running lights, turn and tail for the rear of my trailer, to the main wire bundle from the 12V power source.
The ground wire on the female side of the connector is very loose and will readily slide out of it's slot so I'm looking for something to prevent that. I want to prevent vibration from breaking the connection. This thing is located against the back wall and there is no access to this connector without removing most of the structure of the wet bath. I can tell you from experience that it is not an easy task. I am about to finish putting it all back and this connector issue is holding me up so looking for ideas on something that I can put around where the wires go into it that won't affect the operation.
I have searched all over for this connector to replace it but can only find a place that sells them in a minimum order of 50. Yes, I have been to piles of websites, garages, auto parts places, you name it, been there.
Thanks for any help or suggestions. TB
tinbender is offline   Reply With Quote
Old 07-18-2011, 10:39 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
If that is just a 4 pin connection go to any auto supply store and buy a trailer light kit. Splice in both the male and female connectors in your system.
A trailer light kit will be a water tight connector designed to hand under the rear of the TV so it should meet your needs.
2004 Excursion 4x4
Old 07-18-2011, 11:12 AM   #3
1988 25' Excella
Trumbull , Connecticut
Running light connector
Hello. If you remove the loose pin there should be a tab sticking out the side of the pin. There may be 2 tabs, one on each side. Sometimes the tabs get pushed in so their flat to the pin. If you taks a knife blade and gently pry the tabs so they stick out slighty they will now catch in the connector when you push it back in. Happy camping nm1oqrz
nm1oqrz is offline   Reply With Quote
Old 07-18-2011, 11:30 AM   #4
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Wire vs. Connector Issues
Check with an auto electric service shop. I'm sure that connectot can be found. Wire ends can be replaced with new if wire backs out of connector. Any good electric supply house may also carry them. Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 07-18-2011, 11:31 AM   #5
tinbender's Avatar
2001 16' Bambi
Good ideas but..............
Not a 4 pin, has 6 positions and the wire is bigger than the usual 4 pin, this is 12 gauge.
Tried spreading the tab too, didn't help much. I think the interior of the connector slot is the problem. It's plastic and had to be taken apart when the interior was removed so may have opened it up some.
Thank you both for your ideas. A little better photo.
LED light kit for the Monarch stop tail and turn light Dan@LED4RV Commercial Listings 5 05-12-2014 05:05 AM
Stereo With Overhead light?? Eliminator46 Audio, Video & TV 10 05-20-2011 02:12 PM
first ceiling light Segue Lights - Interior & Exterior 2 05-14-2011 01:18 PM
Flash of Light !! donking General Repair Forum 8 01-24-2011 02:16 PM
