Scare Light Wiring '77 Sovereign 31'
I have been going through all my wiring successfully until I got to fixture for the Scare light which looks a good deal different from others.
It appears that it had a gasket between the stainless light ring and the body. I seem to remember something about dissimilar metals. The gasket seems to be preventing a ground. I can test the red wire going to the light and it works correctly however there was another wire that looks like it was soldered to the base of the bulb which is off. So, I assume I need to keep the metal separated? And, if that is so the wire that is lose is the ground but not sure how it connected to the system ground/ body.
Can some describe how it should be?
Raz
"The road goes on forever and the party never ends" - R.E.Keen
