Old 12-08-2019, 10:22 AM   #1
2013 25' FB Flying Cloud
Traverse City , Michigan
Scare Light way too bright
We have a 2013, 25' FC and have found the scare light to be obnoxiously bright. I'm looking for ideas to either hood the light so it doesnt flood the entire campground or to install a dimmer. Pouring through thousands of forum posts hasn't yielded many ideas...
Alovlien is offline   Reply With Quote
Old 12-08-2019, 10:30 AM   #2
2012 Avenue Coach
Corpus Christi , Texas
Wow, mine was so dim on our '2012 Airstream class b that I installed a brighter led one with two settings. A lower yellow light and a brighter white light setting. But it is a bit bulkier than the one it replaced.
https://www.ebay.com/itm/12-volt-RV-...72.m2749.l2649
A dimmer switch would be nice and not too hard to do in your case. Can you easily get the cover off to see if your current light is incandescent or led? If incandescent, almost any dimmer should work. If led, you may have to replace with a dimmable led bulb and an led compatible dimmer.
rowiebowie is offline   Reply With Quote
Old 12-08-2019, 12:33 PM   #3
1976 31' Sovereign
Oswego , Illinois
scare light
There is a thread that is 5 pages long about this prob. on forums. Title is reinventing the scare light. Type this in search box it will bring up google, scroll down for this title will show for air forums.
Old 12-08-2019, 01:06 PM   #4
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Here's a link.
Shari
RMVAC | WBCCI DenCO Unit | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 12-09-2019, 11:16 AM   #5
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
What's a scare light?
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
WBCCI 9164
cazual6 is offline   Reply With Quote
Old 12-09-2019, 11:24 AM   #6
SuzyHomemakr's Avatar
1972 29' Ambassador
Boynton Beach , Florida
You can get a blue lens for it at Vintage Trailer, I think. When camping with lots of friends, we tell them that when the blue light is on, it's party time, otherwise, leave us alone!
SuzyHomemakr is offline   Reply With Quote
Old 12-09-2019, 12:29 PM   #7
SilverWind's Avatar
2017 25' International
1968 17' Caravel
Los Osos , California
You can place layers of photo filter material under the lens to cut down on intensity and change the tint if you like.
SilverWind is offline   Reply With Quote
Old 12-09-2019, 12:56 PM   #8
2002 19' Bambi
Lafayette , California
Here's another link about shading the scare light: http://www.airforums.com/forums/f542...el-192527.html. I used this for ours: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1. Amazon has another, similar product that is not mirror polished: https://www.amazon.com/dp/B07LCRRYQS...01NAJBWV1?th=1.
Tim
Tim A. is offline   Reply With Quote
Old 12-09-2019, 03:59 PM   #9
richw46's Avatar
Lexington , Kentucky
The scare light is the one on the side of the trailer. Scares away critters.
Name:	Airstream-curb scare light.jpg
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 12-09-2019, 04:06 PM   #10
1976 31' Sovereign
Oswego , Illinois
Tim
Mountain Man did this vent cover on his AS looks very nice. I don't no if he posted a pic but you can pm him for info. He is a very nice person & very friendly plus has a lot of skills & ideas.
Old 12-09-2019, 04:50 PM   #11
1972 23' Safari
Middletown , Rhode Island
scare light cover on mine
I got the blue cover from vintage. I also switched out the bulb to a led, the original bulb started to melt my scare light cover.
Mx468 is offline   Reply With Quote
Old 12-09-2019, 05:13 PM   #12
1966 20' Globetrotter
Tacoma , Washington
Send a message via Skype™ to AirGT65
Turning "scare" light friendly and useful
Here is a (fairly) quick fix for the overly-bright exterior scare light.
Needed: 1) Stainless steel pet dish with 5 1/4 interior rim width, 2) Small roll of 3M two sided exterior "gel"-type tape (Home Depot). Great stuff for all kinds of outdoor projects!, 3) Replacement LED bulb (www.superbrightleds.com - 1157 LED Bulb w/ Stock Cover - Dual Function 36 SMD LED Tower - BAY15D Bulb - Warm White) works well for us.
Process: 1) Remove the clear cover and replace the old bulb with the long-life LED bulb, 2) Reattach the cover and seal with caulk or whatever, 3)Cut down one edge of the dish (I used a circular metal cut-off tool), 4) Attach the cut-down dish around the outside of the light frame, with a thin strip of the two-sided tape.
That's it. Works great. No new holes to drill.
If I were to make another one, I'd make the cut-off slightly smaller - to reduce the glare even more.
I'll try to attach several photos.
ID:	357465   Click image for larger version
AirGT65 is offline   Reply With Quote
Old 12-09-2019, 06:21 PM   #13
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
If you don't currently have an LED in your scare light then maybe someone put an 1156 bulb which is brighter than the 1141 that might have come in it. Take the lens off and check the number on the base of the bulb and replace it accordingly. They have a single contact in the base.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 12-09-2019, 06:26 PM   #14
davidz71's Avatar
1986 25' Sovereign
The 1156 bulb produces 36 candlepower vs. 21 for the 1141 by the way.
Craig
AIR #0078
3.73 rear end
Old 12-09-2019, 06:38 PM   #15
1976 31' Sovereign
Oswego , Illinois
3M also makes golf club grip tape that is 2 sided that is very strong. I use, to put 2 pieces of wood together when turning w/lathe, have to pry apart it is also weather proof. For cutting dog bowl you can also use dremil tool. nice job & good info how to do.
Old 12-09-2019, 08:47 PM   #16
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
Simple , change the bulb to a # 67 it’s half as bright . It’s used in the license light .
Or change the bulb for a led equivalent to the original and change the lens to amber.
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 12-10-2019, 05:06 PM   #17
2017 30' International
Charlotte , North Carolina
We don't have one on our International Serenity.
So first time I heard about "scare lights", I had no idea.
Guess critters are too zen to hang out outside of a Serenity....????
Al U. Minium is offline   Reply With Quote
Old 12-10-2019, 07:47 PM   #18
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by Alovlien View Post
We have a 2013, 25' FC and have found the scare light to be obnoxiously bright..
Umm, that's the idea.
Old 12-15-2019, 02:23 PM   #19
1980 31' International
1962 19' Globetrotter
Naples , N. Idaho
place a piece of yellow/gold nylon cloth inside under lens if it is an LED so it won't get too hot. I have it in all my bright white interior light fixtures. Really helps and is simple.
yarlj is offline   Reply With Quote
Old 12-15-2019, 02:37 PM   #20
mrfixit51's Avatar
Bathurst , New Brunswick
Ideas for lights!!
Hi- i just rebuilt a vintage and used an led license plate light as an entrance light. I then used the scare light of sob as my dinette light ,but changed the bulb to 2 led's. Worked out great with lots of light over the dinette and just a subtle entrance light outside. Just another idea
ID:	357696   Click image for larger version
mrfixit51 is offline   Reply With Quote
Nest outside lights too bright TheHoff Nest 2018 - 2020 7 10-01-2019 04:49 PM
Rear reading lights too bright? jacobo1 Sprinter and B-van Forum 22 11-06-2018 11:32 AM
Scare light and Overdoor light don't work WorkofArt Lights - Interior & Exterior 15 03-05-2014 10:41 PM
Scare light and marker light won't work??? shinybean Lights - Interior & Exterior 12 02-12-2007 09:51 PM
Bright idea for power savers Tinsel Loaf Electrical - Systems, Generators, Batteries & Solar 2 10-05-2003 07:48 PM
