Old 02-15-2017, 05:00 PM   #21
dznf0g's Avatar
Oswego , Illinois
I used a dremmel thin metal cutting wheel. They're really fragile, so a gentle hand is required. But they make short work of it. They have tubes of them plus the arbor at HD here in Oswego.
-Rich-
Old 02-15-2017, 05:19 PM   #22
TRIPPPIN's Avatar
2012 25' FB Eddie Bauer
Southwestern Ontario , Ontario Canada
Send a message via MSN to TRIPPPIN Send a message via Yahoo to TRIPPPIN
Can you use a scare light as a backup light? I want to install LED backup lights and these look like a good use for these. Any idea what one cost?
TRIPPPIN is offline   Reply With Quote
Old 02-15-2017, 05:54 PM   #23
dznf0g's Avatar
Oswego , Illinois
Which taillights are on your unit? Does it presently have back up lights?
They're $25 but that's without the retaining ring
http://led4rv.com/index.php?main_pag...60tdtuo9thmii0
There may be a better way for BUs. I know you don't have the same taillights as mine, but I removed the weak, no reflector 1156 bulb in mine and replaced with the brightest 1156 base led I could find. In addition, and totally by coincidence, I used the cutouts from the dog bowl cover as reflectors. I glued them behind the bulb and now I have really bright, much better focused backup lights which help greatly when backing in a site at night.
-Rich-
Old 02-15-2017, 06:56 PM   #24
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Originally Posted by RLS View Post
Here is what I did to keep it from projecting the light.
I saw your post a while ago, and picked up a 6" dog dish.
but it was too small for my light.
So, I traded it for and 8" one. Picked it up yesterday.
Now can work on it at my leisure.
MelGoddard is offline   Reply With Quote
Old 02-15-2017, 07:11 PM   #25
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
My lens was melted when I bought the trailer and they replaced it then, I found it was cracked when installed. I bought a new lens and got the advertised brightest LED bulb for the fitting I could find. It does not answer the "diffuse" issue for some but the replacement by mere lens and LED bulb worked for me.
WBCCI 8653/AIR 60240
2022 Ford F150 PowerBoost Platinum w/7.2KW
Old 02-15-2017, 09:47 PM   #26
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
LED back up lights
ID:	279920   Click image for larger version
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 02-16-2017, 07:04 AM   #27
TRIPPPIN's Avatar
I have a 2012 Eddie Bauer with signal and stop lamps only. I did not realize some AS had back ups already. I am just looking for something that looks factory in bright LED and not a bumper bolt on. I wonder if there is wiring in there for backups?
Old 02-22-2017, 06:09 PM   #28
RLS. Looks like you started something.
Here's mine that I attached today.
(Had to use an 8" dish, as 6" was too small, and 7" not available.)
Old 02-22-2017, 07:43 PM   #29
LilBigfoot's Avatar
2016 26' Flying Cloud
London , Ontario
[QUOTE=MelGoddard
(Had to use an 8" dish, as 6" was too small, and 7" not available.)[/QUOTE]
Mel....how did you attach the dish? My 2016 light has no visible screws holding it on. Thanks. Don
You're a long time underground!
LilBigfoot is offline   Reply With Quote
Old 02-22-2017, 08:46 PM   #30
I used a 1/8" drill to take three #8×1/2" sheet metal screws, drilling CAREFULLY into the wall.. I also put a bead of clear RTV Silicone on the flange as a seal and an adhesive.
Since the dish was larger than the light, I made a kind of compass to draw a circle around the light using the Centre of the light as an axis.
I used a Sharpie to mark the cicle enabling me to locate the dish at dead centre.
Hope that helps.
Old 02-22-2017, 11:11 PM   #31
2007 22' International CCD
I plan to install a set of halogen lamps in a marine docking light housing. Plan to put low in banana wrap behind axles. Might be bright enough?
Old 02-23-2017, 05:42 PM   #32
2002 25' Classic
Kalama , Washington
Go LED. Halogen gets too hot ... you'll get knee stains from replacing them.
nwclassic is offline   Reply With Quote
Old 02-25-2017, 02:37 PM   #33
The Colonel's Avatar
2017 25' Flying Cloud
Florence , Alabama
Ok, I have the scare light roughly in the middle of AS. I tried to remove what appears to be a chrome coated plastic ring but it doesn't want to come off. Tried to put screwdriver under lip and pry, no joy. Tried to turn ring, same. I'm afraid if I put too much force under ring it will crack. Any help appreciated
The Colonel and Southern Belle
The Colonel is offline   Reply With Quote
Old 02-25-2017, 03:38 PM   #34
Florence , Alabama
How do I get the chrome ring off? I tried prying under edges but it doesn't seem to want to come off.
Old 04-04-2017, 03:24 PM   #35
Boxite's Avatar
2008 22' Safari
Trippin,...here's how I did BackUp lights:
http://www.airforums.com/forums/f295...ts-159403.html
Old 08-02-2017, 08:36 AM   #36
2014 31' Classic
Roanoke , Virginia
I have the same question as The Colonel.. I'm interested in the trip to remove the chrome plastic ring around the Scare light?? It won't come on, but the step light will and they share the same switch.. Thanks!...
LeeJeff is offline   Reply With Quote
Scare light and Overdoor light don't work WorkofArt Lights - Interior & Exterior 15 03-05-2014 09:41 PM
Scare light replacement and wiring Desert64 Electrical - Systems, Generators, Batteries & Solar 6 09-01-2013 04:24 PM
Scare/door light replacement Zeppelinium Lights - Interior & Exterior 2 12-23-2012 07:29 PM
Replace Scare light Zeppelinium Lights - Interior & Exterior 9 03-29-2007 04:32 PM
Scare light and marker light won't work??? shinybean Lights - Interior & Exterior 12 02-12-2007 08:51 PM
