Old 05-29-2013, 06:12 PM   #1
falcon-N-Air's Avatar
1995 34' Excella
Dalton , Georgia
Scare light help!
I am needing a little help with the scare light by the entrance door on our 68 Tradewind. So far all I have done is replaced the bulb. I see two light switches above the entrance door on the inside of the Coach,but after trying both of these I still have no exterior light. Just curious as to what I should try next! All the best!
Eric & Michelle Shuler
1995 34' Excella
2003 Chevrolet Silverado Z71
WBCCI # 7096
falcon-N-Air is offline   Reply With Quote
Old 05-29-2013, 06:45 PM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Mine are 70's/80's vintage and the scare light switch is way forward of the door, it is in front of the big side window near the front curved glass wing window.
The two switches near the door control the porch light and the kitchen sink light.
Yours may be different.
Aaron
WBCCI #XXXX AIR #2495
Old 05-29-2013, 06:55 PM   #3
Full Time Alumaloafer
louaxtjr's Avatar
1966 24' Tradewind
Livingston , Texas
Images: 12
The switch for the scare light on my 1966 Tradewind is forward of the window also. As it happens, I had to pull the switch out and repair the connections due to corrosion at the terminals. Must've been some moisture there at some point.
Lou Axt, Jr.
1966 Tradewind
1969 Chevy C10
_____________
Phillipians 4:13
louaxtjr is offline   Reply With Quote
Old 05-30-2013, 04:42 AM   #4
1995 34' Excella
Dalton , Georgia
Thanks guys, I was a little misleading about the location of the switches, I believe mine are forward of the window also. I will try taking the switch plate off and checking the connections. So one switch possibly controls the kitchen sink light? Many Thanks!
1995 34' Excella
WBCCI # 7096
Old 05-30-2013, 05:31 AM   #5
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
It doesn't control, the kitchen sink light, it works the light overhead just inside the door. turn that light on then try the switch.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 05-31-2013, 03:56 AM   #6
1995 34' Excella
Dalton , Georgia
Thanks Shacksman, I will try that switch for the overhead light,and the other switch should be for the exterior light.
1995 34' Excella
WBCCI # 7096
Old 11-17-2013, 12:43 PM   #7
Cyquest's Avatar
1969 23' Safari
Blenheim , Ontario
My scare light was giving me problems as well. I drilled the 2 rivets holding to wall. Popped it out to see that the wire and connection was green. So I cleaned the connector with a little wire brush and die electric grease. Lit up the whole yard.
Cyquest is offline   Reply With Quote
Old 11-17-2013, 01:22 PM   #8
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I remember the switch as turning on the galley light. Might vary from model to model
