Old 06-01-2016, 11:47 AM   #1
Some Guy
djarrett's Avatar
2018 28' Tommy Bahama
Nashville , Tennessee
Running Lights when not connected?
I saw a picture on the Airstream Addicts Facebook page of a guy who had the running lights on his trailer on for a picture. He did not, however, have his tow vehicle connected. Someone asked and he said there is a fused device that connects to the trailer to truck wiring plug that allows them to be on.
Does anyone know where this can be purchased or what he is referring to?
D
The Jarretts
Nashville, Tennessee
2018 27' Tommy Bahama
2015 F250 TV-Petrol
WBCCI # 22342
djarrett is offline   Reply With Quote
Old 06-01-2016, 12:02 PM   #2
Images: 59
These are usually homebuilt. Get a receptacle end from your local hardware store, add a jumper from the 12V pin to the running lights pin. Put a fuse on the jumper. Wire in a flasher if you want to get fancy. Plug your trailer end into the receptacle and it should work. The lights will be powered by the battery in your trailer.
Old 06-01-2016, 12:07 PM   #3
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
The pins you are looking for in the 7 way umbilical cord are located at 11:00 and 1:00. A blade type buss fuse fits in there nicely!
Old 06-01-2016, 12:10 PM   #4
1976 31' Sovereign
Oswego , Illinois
At trailer connector end take a 10 amp blade fuse and insert on top at 11 oclock and 1 oclock position, or you can, pur. fancy plastic covered fuze if by chance insert wrong no harm done.
Old 06-01-2016, 01:01 PM   #5
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Ditto, a fuse does the trick. Here's a picture.
Brian
SuEllyn & Brian McCabe
moosetags is online now   Reply With Quote
Old 06-01-2016, 02:01 PM   #6
2005 31' Classic
Pleasant Plains , Illinois
I have lit up the running lights exactly per the picture from moosetags. Works fine.
Greg & Mary
2005, 31 ft. Classic - 2008 Ford F250
WGreg is offline   Reply With Quote
Old 06-01-2016, 02:57 PM   #7
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
As usual I over thought this very simple project and created this monstrosity. It has a built in fuse and a selectable flasher.
MICHAEL
Old 06-01-2016, 06:04 PM   #8
2007 22' International CCD
No, you just used the standard engineering approach.
If it isn't complicated, it's NOT engineering. 😀😀😀
KE4GNK/AE
'The Silver HamShack' (2007 International 22FB CCD 75th Anniversary model)
Old 06-01-2016, 06:12 PM   #9
AWCHIEF's Avatar
Images: 33
Well heck, guess I can claim to be an Internet Engineer now.
MICHAEL
Old 06-01-2016, 06:36 PM   #10
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I'm no internet engineer and I didn't go as complicated as yours - but I did rig up a blade connector for the trailer's umbilical with leads connected at 11:00 and 1:00 and fused with a 10a fuse I can swap out if it blows.
I did it this way because I'm too chicken to stick a blade fuse in to the umbilical (too reminiscent of sticking a butter knife in a wall socket for my tastes &#128512.
Was using one at a campsite and my neighbor was fascinated by it. I gave it to him. Can't be more than $9.00 in parts and a couple minutes to put together. You'd have thought I willed him my Airstream!
Simple things tend to make us happy 😀
Name:	ImageUploadedByAirstream Forums1464827504.125456.jpg
Old 06-02-2016, 10:41 AM   #11
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Brian
That's what I do.
I leave the fuse on the kitchen counter near the entry door.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 06-02-2016, 10:45 AM   #12
wavelength's Avatar
1999 25' Excella
Western Springs , Illinois
I have used a 2in piece of 10ga wire and inserted in the trailer plug to join the lead to running lights and the 12v hot lead. Works fine
wavelength is offline   Reply With Quote
Old 06-02-2016, 10:48 AM   #13
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Bzzst!
Old 06-02-2016, 12:56 PM   #14
WBCCI # 23456
2000 30' Excella
Greeneville , Tennessee
I did that a few years ago. It's a great conversation piece.
jimfa440 is offline   Reply With Quote
1976 Argosy 28 Brake lights, turn signals, running lights not working!!! Argosy1976 Batteries, Univolts, Converters & Inverters 6 06-22-2012 05:20 AM
Should interior lights work with no battery but with Tow Vehicle connected bocotim Electrical - Systems, Generators, Batteries & Solar 12 11-03-2011 10:06 AM
1 wire on a new NT30SP not connected is this correct? Thealt Furnaces, Heaters, Fireplaces & Air Conditioning 3 08-14-2011 05:15 PM
TV Charge Line not Connected to AS. GCinSC2 Batteries, Univolts, Converters & Inverters 9 11-03-2010 06:32 PM
Turning on TV lights blows fuse when trailer connected shinybean Lights - Interior & Exterior 4 08-16-2009 09:48 PM
