Old 06-02-2016, 01:07 PM   #15
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Originally Posted by wavelength View Post
I have used a 2in piece of 10ga wire and inserted in the trailer plug to join the lead to running lights and the 12v hot lead. Works fine
No fuse?
MICHAEL
Old 06-02-2016, 01:24 PM   #16
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I have done it with no fuse.
Never had any trouble, but I use a fuse now just to be on the safe side.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 06-02-2016, 01:29 PM   #17
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Originally Posted by AWCHIEF View Post
As usual I over thought this very simple project and created this monstrosity. It has a built in fuse and a selectable flasher.
Would you mind telling us about how you built the flasher function. That would be handy if we had to leave the trailer beside the road in a night time emergency situation.
Old 06-02-2016, 02:19 PM   #18
CRH
1995 25' Excella
xxxxx , xxxxxx
You can put a 552/536 flasher in the socket instead of a fuse for flashing lights.
CRH is offline   Reply With Quote
Old 06-02-2016, 02:35 PM   #19
Tin Man
LY007's Avatar
1983 27' Excella
Charlottesville , Virginia
You can also run a jumper at the fuse box from the hot input wire to the running light circuit. Add a switch and you don't have to go outside.
Steve
83 Excella 27
07 Tundra Limited
LY007 is offline   Reply With Quote
Old 06-02-2016, 03:47 PM   #20
2004 28' International CCD
Daphne , Alabama
Becareful about this
Unless your rig has a plethora of led lights and you want to let the pretties on all night (or even several hours) be prepared for the house batteries to be dead in the morning. There is a lot of load on the batteries with all the incandescent lights flying. Been there done that.
IAMGLG is offline   Reply With Quote
Old 06-02-2016, 03:51 PM   #21
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I put a switch on my interior wall that works my running lights.
Superat stultitia.
Old 06-02-2016, 03:52 PM   #22
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
Reseda , California
Great topic and discussion guys. Now I have to go and over complicate things too. I'm have an app on my phone to flash with my music.
cazual6 is offline   Reply With Quote
Old 06-02-2016, 04:30 PM   #23
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Superat stultitia.
Ok - say more please.... 😀
Old 06-02-2016, 04:56 PM   #24
2008 27' Safari FB SE
Long Beach , California
Or you can just buy one of these plugs from CamperLite: http://camperlite.com/
LBOskiBear is offline   Reply With Quote
Old 06-02-2016, 05:58 PM   #25
AWCHIEF's Avatar
Images: 33
What CRH said. The flasher is kept in the tube and is easily plugged in the ckt. I leave the fuse in line.
That would all the fun out of DIY.
MICHAEL
Old 06-02-2016, 07:13 PM   #26
Silver Star
rucos's Avatar
1970 23' Safari
Victoria , British Columbia
great idea I just walked outside to try it and loved it .... I've got all led running lights so I'm going to try it next time out ....thanks for the tip!
rucos is offline   Reply With Quote
Old 06-02-2016, 09:26 PM   #27
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
It was easy, tap into an always hot 12v circuit that is capable of delivering 10 amps, fuse the tap, run to a switch, and connect the switch to ANY wire that runs to a tail or running light. It will work no matter where you tap in to the light circuit. Near the tail, near a marker, or near the umbilical.
Superat stultitia.
Old 06-03-2016, 04:35 AM   #28
W , New England
Superat stultitia.
Sure does sound easy. Uhm, I have a friend who could probably benefit from pictures or diagrams. If you have any, I'd sure appreciate it - on behalf of my friend who'd need them - I don't, of course...
1976 Argosy 28 Brake lights, turn signals, running lights not working!!! Argosy1976 Batteries, Univolts, Converters & Inverters 6 06-22-2012 05:20 AM
Should interior lights work with no battery but with Tow Vehicle connected bocotim Electrical - Systems, Generators, Batteries & Solar 12 11-03-2011 10:06 AM
1 wire on a new NT30SP not connected is this correct? Thealt Furnaces, Heaters, Fireplaces & Air Conditioning 3 08-14-2011 05:15 PM
TV Charge Line not Connected to AS. GCinSC2 Batteries, Univolts, Converters & Inverters 9 11-03-2010 06:32 PM
Turning on TV lights blows fuse when trailer connected shinybean Lights - Interior & Exterior 4 08-16-2009 09:48 PM
