Old 12-23-2011, 04:26 PM   #1
1970 31' Sovereign
Burnsville , North Carolina
Running Lights on a '71 Sovereign
Hi Guys, another question or two from a new owner - (1) can you turn on the exterior lights without being hooked up to a vehicle? I did flip the single switch to the left of the front curbside window and one white light went on. (2)There are two other switches right inside the front door. What are they for? (3) Anybody know where I might find plastic light shades and knobs for the three ceiling fixtures? If not, what have you replaced these with?
Thanks in advance for any help you may lend.
Bill
CeloNC is offline   Reply With Quote
Old 12-23-2011, 05:31 PM   #2
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Bill - welcome to Airforums. You can find the light covers here. They also have the replacement switches. It's my understanding your vintage knobs won't fit these switches but you may want to call them to confirm, if that is important to you. I took mine apart and cleaned them in order to retain the original knobs. Dimmer switch knobs from Lowes, etc. should fit the new switches if you go that route.
Electrical Inside : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
Old 12-23-2011, 09:42 PM   #3
Maniacal Engineer
barts's Avatar
Menlo Park , California
If you want to turn on the exterior running lights, the simplest, cheapest solution is to grab a 10A blade-style fuse and connect the two top sockets in the umbilical together. These are the two connections on either side of the raised "key" on the connector that fits into the top of the 7 pin socket on the tow vehicle.
Quick & simple. This will drain your house battery if you're not plugged in, of course.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 12-24-2011, 04:34 AM   #4
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Use of the blade fuse works, if you have the GM type round connector with flat contacts, rather than the round pin connectors.
Old 12-24-2011, 08:06 AM   #5
Wise Elder
Jammer's Avatar
2010 30' Classic
Welcome to the forums.
The white light, variously called a "scare light" or "porch light," does turn on from the switch by the door. It's there to help you see when outside the trailer at night, or when evaluating the identity and intentions of any visitors arriving after dark.
Although adding an interior switch to turn on the running lights is a common modification (I have done this to my trailer for example), trailers did not have this feature from the factory. It is also common for people to turn on the running lights by shorting the connector to the tow vehicle, as Bart describes.
They control interior lights. You'll have to be sure the switches on the lights themselves are on, too, for them to work.
[/QUOTE]
Old 12-24-2011, 10:33 AM   #6
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
If you need to replace the old ceiling lenses, and switches ( try Inland RV and Vintage Trailer Supply) you might consider switching to 12v LED units which will use a whole lot less battery if you are boondocking.
Lumatic is online now   Reply With Quote
Old 12-25-2011, 07:08 PM   #7
1970 31' Sovereign
I checked and unfortunately, I have the old 7 pin connector. So, I am still looking for a way to turn on the running lights w/o a battery. Any suggestions?
Thanks, Bill
Old 12-25-2011, 07:23 PM   #8
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Use a battery charger. Connect the black lead to a clean spot on the frame then connect the red lead to the terminal on the 7 pin connector that is for the running lights.
TG Twinkie is online now   Reply With Quote
Old 12-25-2011, 07:52 PM   #9
Lumatic's Avatar
1993 34' Excella
Images: 16
A short jumper wire from the hot wire position to the lights position will doer.
sovereign
Keeping running lights on while camping RichHog Lights - Interior & Exterior 45 07-25-2017 02:16 PM
Help! Running lights problem mimiandrews Lights - Interior & Exterior 13 01-03-2012 02:22 PM
Street side brake light not working w/ running lights on NicheVintage Lights - Interior & Exterior 7 08-23-2011 05:54 AM
Running Lights LED - How do I route the wire? AirHome Lights - Interior & Exterior 6 02-20-2011 07:15 PM
Lens removal for orange running lights on 1973 model AirHome Lights - Interior & Exterior 6 02-07-2011 09:42 PM
