Old 05-01-2012, 08:54 AM   #1
1989 29' Excella
Cumming , Georgia
Running Lights on a 1979 Not working
Hi,
I'm looking at 79 Argosy. The seller says the running lights are not working. thinks it's a short. I've asked him if they've ever worked. Waiting for a reply.
The question(s) I have are,
Is fixing non funcitonining running lights for a non electrition type a, 'DIY', thing or would I need to take to an airstream dealer for repair?
I kind of think that since all of them are not working then it most likely is a short at the point all the lights come together.
Thanks for the help.
Dave
davcarv is offline   Reply With Quote
Old 05-01-2012, 09:28 AM   #2
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
I would start at the 7 pin plug, the the fuse box, and then check continuity between the box/plug and box /lights. That will at least narrow down the problem area and give you a good starting point.
1982 34' Limited
2000 Excursion V10 4x4
WBCCI #3321
TAC #GA-24
c_lewis77 is offline   Reply With Quote
Old 05-01-2012, 11:01 AM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Could be you need to re-wire the umbilical to match the current standard. I know early 70's airstreams used a much different standard for the umbilical than what is standard now. Not sure how that would apply to a '79 Argosy, but something to check out before you go looking for broken wires, shorts, etc. Buy a new 7-pin trailer connector and wire it according to the diagram it should come with. That might solve the problem.
Chris
Old 05-02-2012, 06:54 AM   #4
1989 29' Excella
Cumming , Georgia
thanks guys,
So, ... a follow on question is that I don't think i'd want to buy a coach where the lights don't work. Is this a solvable problem? Would an airstream dealer be able to fix it? Would it be expensive? Is it a Do It Your self thing? I'm not very knowledgable about electical systems. I mean i can hook up a light but that's about it.
Old 05-02-2012, 08:28 AM   #5
Splitrock's Avatar
Sioux Falls , South Dakota
A '79 might be a cherry of all cherry trailers and it might be the best thing you ever bought. Fix the lights and everything else is perfect and nothing will leak or break. Or, it might be a time and money pit.
I fix up old trailers, so if the price is right and I like the trailer, I'd buy it. My lights didn't work when I bought mine. I had em working in short order.
Old 05-02-2012, 10:04 AM   #6
Kevin245's Avatar
Originally Posted by davcarv
thanks guys,
Hi Dave,
Is this solvable? Yes it is and a dealer could certain do this for you, though many here (self included) would consider this DIY work. The lights typically run on different circuits, so if a group of them are not functioning then I would suspect a fuse or trunk line issue. I don't think that would be an expensive fix, and it is certainly something the members here could gladly walk you through.
If it was caused by a short in the feeder lines to the individual lights then it might get a bit tricky, but still solvable. These systems are not complicated. Accessing things is usually my issue, as it always seems that whatever needs repair is located in the least accessible part of my trailer.
If the price is right I wouldn't necessarily rule the rig out because of this. You could certainly use it as a negotiating chip.
Eleanor Roosevelt
Old 05-02-2012, 12:33 PM   #7
Splitrock's Avatar
In my experience, running lights is a minor issue on a 33 year old failure prone trailer.
Yes! Yes! Probably!
It is for me. Since you are concerned about it, you may not be comfortable trying.
If your experience is like mine, nothing will work once you get the trailer. What is working will quit on your first trip. Lots of these old Airstreams have floor rot, frame damage, bad axles, nonworking air conditioners, leaking plumbing, worn out appliances, bad converters, dead batteries, too old tires, broken windows, leaking window gaskets, bad vents, and leaking roof seams.
That's for starters.
Old 05-02-2012, 01:39 PM   #8
1989 29' Excella
Cumming , Georgia
UGH, ... I struggle with the knowledge of the reality of old and new.thanks for the feedback. ...
Old 05-03-2012, 04:56 AM   #9
1989 29' Excella
Cumming , Georgia
Little confused by your response about error prone 33 year olf trailer
Do you mean being so old a trailer in general is error prone or that model IRS error prone or both?
Dave
Old 05-03-2012, 05:47 AM   #10
Skater's Avatar
1995 30' Excella
Bowie , Maryland
What he's saying is that it's an old trailer and things are likely to go wrong. You wouldn't expect a 33 year old car to be in perfect condition, nor would you expect a 33 year old house to have working original appliances.
And this issue specifically: We can't diagnose it over the internet - you need a multimeter and some time to start tracing the wire, starting with the plug on the front of the trailer that hooks to the tow vehicle.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 05-03-2012, 07:14 AM   #11
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I doubt there would be wiring problems within the walls of the trailer. Most problems are with ground connections, UCord not wired to match the TV, bad bulbs, bad connection between the bulb and socket.
To my knowledge there are no fuses in the external lighting system. Fuses in the TV provide the protection for this wiring.
I would start by using a portable battery charger as a 12 volt power source. You can check the circuitry without the fear of blowing something up.
There are only 5 circuits and the ground/common to check out.
1. Tail/marker lights
2. Left turn
3. Right turn
4. Electric Brakes
5. Charge Line
Plus the ground/common
There are plenty of members here with the knowledge to walk you thru it. We will be glad to help.
Old 05-03-2012, 07:26 AM   #12
1989 29' Excella
Cumming , Georgia
thanks for the responces guys. I really appreciate them. Very helpful.
Now if I could only get the seller to reply to my email/phone call.
ugh
Old 05-03-2012, 08:47 AM   #13
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
Bad wiring is possible, but can be fixed
We had a running/marker light problem with our '66 Safari last winter. Turned out to be bad wiring to the front set of lights. It took some fishing, but new wiring and new lights for the entire circuit was well within a do-it-yourselfer's capability.
See my thread from that time at
http://www.airforums.com/forums/f447...lem-85885.html
mimiandrews is online now   Reply With Quote
Old 05-03-2012, 06:08 PM   #14
Splitrock's Avatar
Dave
I wrote: "a 33 year old failure prone trailer"
What has not already failed is about to. The design of the trailer predicts leaking, wood rot, and steel rust. All of the components are past their life expectancy or near the end. Every item must be useful and safe. For me, that means new.
My budget for my next 33 year old travel trailer will be in the area of $14,000 (parts only) above purchase price to repair and replace. I don't want a trailer with any body damage at all and I don't want a trailer with any major frame damage. Backup lights, I can fix.
