Old 02-20-2011, 12:29 PM   #1
AirHome's Avatar
1973 29' Ambassador
San Diego , California
Running Lights LED - How do I route the wire?
There is great information here about upgrading running lights to LED, so I am making the attempt. I am curious how others have routed the wire in the back of the LED. As you can see in my pictures, on the new LED light the wire sticks out the back in a way that the light can not lay flat against the skin of the Airstream.
Also on the Airstream, the grommet for the existing wire sticks out. This also interferes with mounting the new light.
Should I be drilling a new hole and rerouting the wire?
Did I purchase the wrong running lights for my year and model?
Any advice is appreciated!!
ID:	122649   Click image for larger version
AIR HOME - 73' Ambassador International
Remodel blog: Air Home
Work: http://www.emaxaction.com/
AirHome is offline   Reply With Quote
Old 02-20-2011, 12:55 PM   #2
Open up the hole to accomodate the new location of the wiring.
Make sure you also "ground" one side of the new LED clearance lights.
After the lights are installed, add a small bead of sealer, completely around the base of the light.
I am not aware of any LED clearance light that has wiring that matches the original lights. In that context, no, you don't have the wrong lights.
You can use Par-bond or Vulkem.
Old 02-20-2011, 01:04 PM   #3
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
I think consensus will be that drilling more holes in Airstream skin is invitation for more water to move in and make floor and upholstery damp...
Not sure how those were matched to your trailer, but we've had success just replacing small press-in bulbs with LED versions... If You really want to surface-mount, I'd consider making a spacer plate under the new light wth a channel for the wire, and seal it well with non-silicone sealant when you put it together...
(Wetness is to be feared more than a little darkness... )
Condoluminum
Condoluminum is offline   Reply With Quote
Old 02-20-2011, 02:39 PM   #4
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
spacer plate
I used the base from the original lights. Cleaned out the old sockek and connections. The new light matched up to the old base. Used stainless sheet metal screws thru the new light and the old base. One of these is where you put the ground. Between the new fixture and the old base there is 1/4 inch for the hot wire connection. Like Andy said be sure to butter everything up. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 02-20-2011, 06:32 PM   #5
AirHome's Avatar
1973 29' Ambassador
Thumbs up Made adjustments to the light case
I didn't want to make another hole (I've got enough leaks), so I played with the light itself and found I could etch away some plastic enough to make the wire lie flat. I tried to work with the grommet and realized I couldn't get it to work. I ditched it and just made sure I sealed everything up well.
I am happy with it. The first one took 3 hrs. The second took 30 minutes.
Thanks all for the advice.
ID:	122692   Click image for larger version
Old 02-20-2011, 06:54 PM   #6
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
As Andy said seal the edge. I would run a bead of sealant from the left side around the top to the right side but not along the bottom. Use grey Parbond Aluminum Sealer 5524 I believe is the better one to use on the outside skin.
Parbond Aluminum Sealer 5524 [SC-0274] - $7.49 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
Good Luck - LED's are cool
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 02-20-2011, 07:15 PM   #7
AirHome's Avatar
1973 29' Ambassador
Yep. I've got Parbond on order.
Thanks!
led, running lights, wires
LED Lights on 87 345 rear tail/turn Myrtle lynn Classic Motorhomes 19 02-28-2011 09:43 PM
Upgrading to LED lights denali Lights - Interior & Exterior 17 02-20-2011 09:10 AM
LED Interior lights Matt Kline Lights - Interior & Exterior 1 02-19-2011 05:31 PM
Minus these lights SilverHoot Lights - Interior & Exterior 20 02-13-2011 09:04 AM
Lens removal for orange running lights on 1973 model AirHome Lights - Interior & Exterior 6 02-07-2011 09:42 PM
