Old 12-26-2014, 02:16 PM   #1
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
1964 17' Bambi II
Laramie , Wyoming
Images: 11
Running lights for evening ambience
Here's a little trick I learned to provide evening ambience with the trailer lit up with its running lights while Click image for larger version
Name:	ImageUploadedByAirstream Forums1419628483.068963.jpg
ID:	229263Click image for larger version
Name:	ImageUploadedByAirstream Forums1419628514.042629.jpg
ID:	229264Click image for larger version
Name:	ImageUploadedByAirstream Forums1419628538.309546.jpg
ID:	229265not plugged into the TV. This is a simple electric plug with its prongs bent out to match the angle of the 7-pin trailer inlet and the two wires spliced together. Plug it into the 11 and 1 oclock pin holes and the tail and running lights light up. My only question is would be am I apt to damage anything by lighting up the trailer this way for long periods?
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, 2018 Toyota Highlander
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 12-26-2014, 02:26 PM   #2
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Your method is novel, but this is a time honored Airstream tradition and will not harm anything. Most people use a piece of thick gauge electrical wire to bridge the connections on the seven pin. Obviously if you are on battery power, this will add another load to the batteries, but if you are on shore power, go for it!
Bob Martel
WBCCI# 5766
Old 12-26-2014, 02:39 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I added a fuse to my little jumper, just in case. I also have it wired where I can plug in a flasher if necessary.
MICHAEL
Old 12-26-2014, 03:00 PM   #4
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
There is another thread about this- Running Lights on While Parked (?)-
I use a mini blade fuse for a jumper. I used to use just a short piece of wire, but someone suggested a fuse was a good idea.
How do you haul the tandem bicycle?
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 12-26-2014, 03:01 PM   #5
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
You really don't have to built anything to get a fused connection to turn on the Airstream running lights while the trailer is not hooked-up.
An old timer showed me this trick years ago. Take a 10 amp large size automotive fuse and plug it into the the two connectors on either side of the key on the trailer's umbilical cord. It is the simplest way to get the runnong lights going with a fused connection.
Brian
SuEllyn & Brian McCabe
Old 12-26-2014, 03:12 PM   #6
m.hony's Avatar
2013 30' Classic
Yep, moosetags, that's what I do-
I first took a spare fuse from a friend's GMC truck (mine are smaller and have different connections). I then put a small package of spare fuses from the auto parts house in the trailer.
TAC #MS-10
Airforums #70955
Old 12-26-2014, 03:13 PM   #7
AWCHIEF's Avatar
Images: 33
Brian, that is just way to simple. You know the kitchen table engineers here, they have to over think every little issue.
MICHAEL
Old 12-26-2014, 03:19 PM   #8
m.hony's Avatar
2013 30' Classic
Before I came to that conclusion, I stood in the trailer section at Walmart looking at fuses, wire, trailer plugs- over-engineering a $20 device- then I said, "This is way too complicated," and walked off to go back to the campground and mull it over, talk to other campers, sleep on it, check 'forums-
Maybe we should check 'forums first-
TAC #MS-10
Airforums #70955
Old 12-26-2014, 03:27 PM   #9
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I put mine on a switch by my front door.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 12-26-2014, 03:31 PM   #10
AWCHIEF's Avatar
Images: 33
How did you manage that?
MICHAEL
Old 12-26-2014, 03:34 PM   #11
AWCHIEF's Avatar
Images: 33
Lots of good ideas here,
http://www.airforums.com/forums/f447...ing-59634.html
MICHAEL
Old 12-26-2014, 03:48 PM   #12
m.hony's Avatar
2013 30' Classic
Yep. That is the thread I incorrectly referenced earlier. There are pictures of my trailer lit up after dark on that thread.
Some suggest it is obnoxious or rude. I disagree. I turn it off at bedtime/quiet hours.
TAC #MS-10
Airforums #70955
Old 12-26-2014, 03:56 PM   #13
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Well, I had previously wired my backup lights to work off the same switch.
I ended up eliminating the backup lights in favor of doubling the tail and signal lights, so I just wired my switched lead into the running light circuit.
It would be fairly easy to put a switch near the rear of any trailer to accomplish this though.
Old 12-26-2014, 04:30 PM   #14
m.hony's Avatar
2013 30' Classic
I leave my fuse lying on the kitchen counter right by the entry door so I can light it up whenever I get the whim.
TAC #MS-10
Airforums #70955
Running Lights don't work, Other exterior lights work jrvly1976 Lights - Interior & Exterior 15 01-27-2015 09:27 PM
Airstream featured in the Saturday Evening Post rec Airstream "In the News" 4 03-12-2010 02:53 PM
No running lights or tail lights... goswick Lights - Interior & Exterior 24 02-27-2010 09:31 AM
Running Lights/Backup Lights 85 Sovereign GRAYMAN Lights - Interior & Exterior 7 08-10-2004 08:54 AM
