Old 12-26-2014, 04:36 PM   #15
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
I just do like moose tags & m.hony, works fine and dandy.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 12-26-2014, 04:44 PM   #16
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
1964 17' Bambi II
Laramie , Wyoming
Images: 11
Now this is interesting. Where have I been all this time? You folks have been turning on your running lights for years. I never heard of it till just the other day. And I've been on this forum for a dozen years and Airstreaming for 14 years. I like Brian's fuse idea...just for a little extra safety. $29.95 plus $4 shipping for a Plug-n-Light? Even Andy at Inland says to just make a simple connector.
For m.hony: The tandem bike rides in the pickup bed.
Jay
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, 2018 Toyota Highlander
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 12-26-2014, 05:29 PM   #17
2015 25' FB International
Advance , North Carolina
How to carry a tandem
Same way here, Jay, a 2x4 across the truck bed with a fork mount and the long bike diagonal across the bed. Works great!
Bruce AD4ET & Marcia KE4JZE
WBCCI #5027
TinCloud is offline   Reply With Quote
Old 12-26-2014, 05:50 PM   #18
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
My long wheel base recumbent fits snugly in the truck bed diagonally with no bracing or mounts- just put it in there and close the tailgate on it.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 12-27-2014, 09:30 AM   #19
1964 17' Bambi II
Laramie , Wyoming
Images: 11
Name:	ImageUploadedByAirstream Forums1419697281.537263.jpg
My bike carrier is a Yakima meant to be mounted across the top of a pickup bed. I cut it to fit within the bed and shackled it to the rear corner tie-downs. Found it at a swap meet years ago. Don't know if they still make it. The blue thing you see here is a coupler for my thru-bolt forked fat bike. The Santana sits on the other side of the bed.
Antique Pedaler
Old 12-27-2014, 10:05 AM   #20
prairieschooner's Avatar
1958 18' "Footer"
Idyllwild , California
Originally Posted by moosetags View Post
You really don't have to built anything to get a fused connection to turn on the Airstream running lights while the trailer is not hooked-up.
An old timer showed me this trick years ago. Take a 10 amp large size automotive fuse and plug it into the the two connectors on either side of the key on the trailer's umbilical cord. It is the simplest way to get the runnong lights going with a fused connection.
Brian
I like this one, easy and noninvasive! will need to try this someday.
Steve
1958 California Built 18' #18-4092
http://www.airforums.com/forums/f106...on-122678.html
prairieschooner is offline   Reply With Quote
Old 12-27-2014, 10:25 AM   #21
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Think it is just your running lights? It is your tail lights too. I am with those who think its rude to have those bright lights glaring in a beautiful starry night.
Old 12-27-2014, 12:47 PM   #22
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
One thing is certain, no matter what a person does, or does not do, someone, somewhere, is going to be offended.
There will be a few instances where it might be improper to burn my trailer lights, and in these instances I will likely abide, but it is simply ludicrous to state that burning these lights in the presence of others is always rude.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 12-27-2014, 05:01 PM   #23
E Pluribus Aluminus
Jaxon's Avatar
2008 34' Classic S/O
1967 22' Safari
2005 30' Classic
Rockport , Texas
Send a message via AIM to Jaxon Send a message via Yahoo to Jaxon
Artstream (Michael Deprada), attached a low voltage rope of blue lights under his AS so that at night when lit, it looked like it was plasma powered and ready to float off... the lighting was low and certainly not bright. Rarely offended, often attracted.
Now, if they’d just take the tin foil off their heads, it’s messin’ with my reception.
Bill & Kim
WBCCI 7005 * AIR 9218
The trouble with trouble is it always starts out as fun...
Jaxon is offline   Reply With Quote
Old 12-27-2014, 07:23 PM   #24
m.hony's Avatar
2013 30' Classic
No brighter than lanterns, campfires, rope lights, flashlights, etc.
TAC #MS-10
Airforums #70955
Old 12-27-2014, 09:31 PM   #25
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Given that it offends some and not others and apparently those that it does offend have no rights, and the lighters are for no reason that I can fathom other than to draw attention to themselves, are lighting all the adjacent campsites around them; Could someone please explain to us non lighters what benefit the lighter gains from this annoying practice?
Ken
Old 12-27-2014, 09:55 PM   #26
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Ken
Hi, for me, it's just at Airstream Rallies where I turn my lights on at night. [not all night] and I only go to one Rally per year.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 12-27-2014, 11:32 PM   #27
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Running lights for evening ambience
Ken
No one "needs" an Airstream either. I am sure there are some folks who wonder what purpose those silly trailers serve and thinks that they have no place on the road.
It must be that everything is not about need.
EVERYTHING offends someone. Some people might even be offended that others are offended at their lights.
Whose offense takes precedent?
Old 12-27-2014, 11:53 PM   #28
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
I like all the light ideas. If you build or buy one that flashes it is an added safety factor when you are stranded on the side of a dark highway. Of course the required 3 reflective triangles help too.
Running Lights don't work, Other exterior lights work jrvly1976 Lights - Interior & Exterior 15 01-27-2015 09:27 PM
Airstream featured in the Saturday Evening Post rec Airstream "In the News" 4 03-12-2010 02:53 PM
No running lights or tail lights... goswick Lights - Interior & Exterior 24 02-27-2010 09:31 AM
Running Lights/Backup Lights 85 Sovereign GRAYMAN Lights - Interior & Exterior 7 08-10-2004 08:54 AM
