Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 12-05-2003, 09:36 PM   #1
Barkingspider
Barkingspider's Avatar
Profile:  Austin , Texas
Question Running Lights
I recently purchased a 1987 29' Sovereign which had been recoated in Ohio 3 yrs ago. When they did the recoat they did not remove the running lights and the acid they used to strip the trailer really tore them up. I went by an Airstream service center in Dallas to pick up some replacements and when I got home realized the new lights they sold me are not an easy swap. The old ones have one wire hole in the upper right hand corner and one wire hole in the lower left hand corner. The new lights have both wire holes at either the top or bottom (depending on how you orient the light). Also the new lights don't have the adapters to slide the stock connectors in.....they would have to be hard wired. Does anyone know if I can purchase replacements that match the original lights?
Barkingspider is offline   Reply With Quote
Old 12-06-2003, 01:42 AM   #2
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
I'd call Andy and see what he has:
http://www.inlandrv.com/
Eric
Old 12-06-2003, 05:45 AM   #3
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
looking for this?
they are manufactured by grote industries.
you should be able to find them at any truck stop or parts house, napa etc.
john
grote
you call them ferrets, i call them weasels.
Old 12-06-2003, 08:22 AM   #4
87MH
87MH's Avatar
Profile:  1978 31' Sovereign
Katy (West Planet Houston) , Texas
Images: 162
Bullseyes
The picture that John posted (the same as on the '87) are availavble at virtually all parts houses.
The LED versions are now out at the Big Rig parts houses (Peterbilt, Freightliner, Mack) at about $10 each (either red or amber). Watch the number of LED's in the body, as both 5 light and 7 light units are out there.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign Photos:'78 Sovereign Rebuild
Motorhome '87 Classic Motorhome Saga
Old 12-06-2003, 10:34 AM   #5
Barkingspider
Thanks to all for responding - I just talked to the shop that I bought the lights from and they cleared it all up for me. It seems the old lights on my trailer had a positive and a ground wire that had to be hooked up. The new lights only have a positive wire and the lights ground themselves to the trailer when you screw them on. Problem solved!
Old 12-11-2003, 08:55 PM   #6
Sue&Von
Profile:
Did the front and rear center triple running lights have a cast aluminum bezel or trim that the plastic assembly fits into?
All the side markers and corner marker lights have the cast bezels.
I am thinking maybe someone did away with our front & rear bezels when changing out the assemblies. It's a 1974.
If the bezels did exist are they still available Andy?
S&V
Sue&Von is offline   Reply With Quote
Old 12-11-2003, 09:05 PM   #7
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
The center three markers, front and rear did not have the aluminum bases like the corner lights. They are attached directly to the skin.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 12-11-2003, 09:48 PM   #8
smily
"Still Working"
smily's Avatar
Profile:  North Charleston , South Carolina
Lights
Actually, The photos posted above are not the replacements. The replacements have two bulbs which kind of look like two "bull eyes" one on each half of the lens.
You can buy them at Wal Mart for much less than the RV stores are asking. The units are typically plastic based but you can buy the cast metal based ones from any trucking supply store or truck stop.
The cast units blend a little better and they are not effected by a solvent such as paint stripper. The lights come with one connection and ground to the skin via the screws that hold them in place. They are a Grote product but the lights are manufactured by several manufacturers including Signal Stat who is now Truck lite.
Th old units have a metal receptacle which in time lose there retaining "spring" The new ones are plastic based and come with a light bulb that resembles a Yard light bulb, All glass with no metal base. Last a long time.
The replacement cost around 3 dollars each at Wally world and you can pick them as cheap a 1 dollar at Harbor Freight tool stores and truck stops.
Been there done that many times.
Smily
Ken Smillie
My 1994 36' Classic MH is for sale
See it in the classifieds
smily is offline   Reply With Quote
