Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 03-23-2006, 03:19 PM   #1
cameront120
cameront120's Avatar
Profile:  1972 25' Tradewind
Running Lights
Is there normally a gasket that sits between the plastic body of a running light and the exterior aluminum skin of the trailer? How is this junction normally made water tight. I've discovered a small leak and suspect that this might be the source. Thanks in advance!
Cheers!
Cameron & the Labradors
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
http://northvancouvermodern.blogspot.com/
Old 03-23-2006, 06:30 PM   #2
overlander63
Rivet Masher
overlander63's Avatar
Profile:  L.A., Dammit , California
Most do have gaskets. At least the factory applied ones. I have used several things over the years to keep water out, from clear silicone, to butyl rubber, to gasket material, to Silkaflex. Some things seemed to work better for me, such as the butyl rubber, and Silkaflex.
Old 03-23-2006, 07:51 PM   #3
cameront120
Thanks Terry. Where would I get butyl rubber? Does it come in sheets? Actually, I think I discovered where the water is coming from. Down where the belly pan meets the side skin (right at the rub rail) adjacent the front goucho, there seems to be a bit of separation that has been slowly letting in water for who knows how long. The damage to the plywood is pretty small (less than a foot square), so I think this small leak has been around for a while. Should I seal the leak with Silkaflex, or is there something else I should be doing? I think I will remove the front goucho and cut out the damaged plywood and replace it with new marine grade plywood, as the damaged wood is quite soft.
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
Old 03-23-2006, 09:03 PM   #4
bake315
bake315's Avatar
Profile:  1994 34' Limited
Elgin , Texas
Images: 161
Typically you can buy it (butyl rubber) in a tube and apply it just as you would caulk.
Cheers, Dave
"Finish."
AIR #4188
1994 34' Limited / 2002 Chevy 3500 CC 4x4 D/A Equal-i-zer Hitch / Jordan Ultima 2020
bake315 is offline   Reply With Quote
Old 03-23-2006, 10:23 PM   #5
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
You can also get butyl tape. It's the roll of stuff that you use around and under roof vents for water-proofing. It cuts with a razor knife and has a bit of adhesive quality......would make for great gaskets!
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
two tiny orange lights on left front side trailer overlander Lights - Interior & Exterior 19 12-12-2003 08:39 AM
marker lights dont work wb13798 Mechanics Corner - Engines, Transmission & More... 6 11-09-2002 12:40 PM
Broken wiring in tail lights Argosy74 Electrical - Systems, Generators, Batteries & Solar 4 10-23-2002 10:09 PM
Trailer lights Dbraw Electrical - Systems, Generators, Batteries & Solar 1 09-13-2002 05:51 PM
Rrunning Lights niftypkg Electrical - Systems, Generators, Batteries & Solar 7 08-22-2002 11:30 AM
