Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 05-28-2008, 09:50 PM   #1
Wayner 76
Profile:  1976 31' Excella 500
azle , Texas
Running light problems
I have a 76 sovereign & cant get the running lights to work. My tv is a04 F350, The plug has power on my test light until I plugin then it loses power on both sides. I have wired lots of trailers before but never any rv trailers with their own power source
Wayner 76 is offline   Reply With Quote
Old 05-28-2008, 11:29 PM   #2
Andrew Selking
My Grandparents Airstream
Andrew Selking's Avatar
Profile:  2007 25' Safari FB SE
Fort Worth , Texas
I had this same proplem with my trailer. What I found was a bad spot in the ground wire on the trailer where the cable had been repaired many years ago, before it wen't into the trailer. Respliced it and has worked ever sense.
Andrew Selking
WBCCI #6062 VAC
"Airstream the Best trailer ever built."
Andrew Selking is offline   Reply With Quote
Old 05-29-2008, 07:30 AM   #3
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
I agree. More times than not, it's usually a grounding issue if your TV and connections are checking out OK.
Old 05-29-2008, 08:30 AM   #4
Lumatic
Lumatic's Avatar
Profile:  1971 25' Tradewind
1962 28' Ambassador
Estancia , New Mexico
It does sound a lot like a ground problem. It's also possible over the past 30 years of so someone messed with the wiring. As far as the "rv trailers with their own power source" the running, brakes and turn lights run off the TV not the battery in the coach.
I have my own opinion. Don't confuse me with the facts.
running light corrosion altamont Lights - Interior & Exterior 4 05-20-2008 09:03 AM
77 argosy running light wiring help? Tamara Lights - Interior & Exterior 4 05-10-2007 06:02 AM
Running Light Leaks bhunt Lights - Interior & Exterior 4 05-15-2006 12:18 PM
Running light question jcferguson Towing, Tow Vehicles & Hitches 9 11-01-2005 10:07 AM
Retainer Screw on running light? stevepdx Lights - Interior & Exterior 1 02-05-2005 04:43 AM
