Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 05-15-2006, 06:19 AM   #1
Happy Trails
bhunt's Avatar
Profile:
Running Light Leaks
Has anyone else had water in their running lights? We have two 2005 Airstreams and both have leaks in the red or amber lights. I have taken both to the factory as it isn't far from us, and the Airstream technicians added silicone inside the edge of the fixture and where the screw compresses the plastic into place, but even this has not always worked. Has anyone else had this problem and come up with a good solution? It really rots out the fixture quickly if not addressed.
bhunt is offline   Reply With Quote
Old 05-15-2006, 09:13 AM   #2
Turtle's Avatar
Profile:  2004 16' International CCD
Arcata , California
bhunt, It looks like you have a 16' Bambi also. I had the exact same problem with ours and my solution was the same as the Airstream tech's. Silicone around the lens and screw. It did the trick and the test lens I popped off did so without breaking. The gasket on mine seemed more like a sponge than a seal and there was nothing around the screw. Owning anything is all about tweaking. Enjoy, Jamie
Turtle is offline   Reply With Quote
Old 05-15-2006, 09:22 AM   #3
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Frozen Tundra , Illinois
Lew (I think he goes by Lewster on the forum) came up with a kit that not only included stainless screws, but a rubber type grommet that seals the light. I haven't installed them yet, but the kit looks awesome and he said it stopped his leaky lights!
Old 05-15-2006, 10:19 AM   #4
Profile:  2005 25' International CCD
1954 22' Flying Cloud
1957 22' Flying Cloud
Simi Valley , California
yesterday while washing and waxing my 2005 AS for this coming weekend rally at newport dunes, i noticed the same thing. all my clearance lights were fogged over on the interior and the lense attachment screw was rusted.
Kevbo10 is offline   Reply With Quote
Old 05-15-2006, 11:18 AM   #5
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Hi All,
I have the solution....and it does not involve silicone!! (bad stuff on any RV!!). Check in the classified section under parts and you will see the photo and other pertinant info. It solved the leak problem on my 19CCD!!
PS: Thanks for the head's up Twink!!
Lew Farber -Certified Master RV Tech (currently on Forums posting sabbatical, but lurking in the background )
WBCCI #1456 and about to resign!/VAC (assoc) #1456/ AIR # 10325
TAC# OR-1
CHARTER MEMBER: FOUR CORNERS UNIT
Hitch light plugs ALANSD Brakes & Brake Controllers 4 10-12-2002 09:04 PM
Running the roof A/C when traveling ... Hayseed Airstream Motorhome Forums 3 07-21-2002 08:16 PM
Furnace won't light /stay lit Don Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-29-2002 03:37 AM
Finding water leaks FrankR Plumbing - Systems & Fixtures 0 06-27-2002 08:36 AM
Clearance light wiring Bob Evans Lights - Interior & Exterior 6 05-27-2002 11:03 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
