Old 11-14-2011, 06:56 AM   #1
1974 25' Tradewind
Berryville , Virginia
Running light has no power
I have a running light on the curbside end of the trailer which has no power. What I would like to know is where AS ganged the wiring harness for these three lights, was it down by the turn singnal housing ? The only solution I have is to fish a wire to the one next to it to get juice. Any suggestions?
batt is offline   Reply With Quote
Old 11-14-2011, 07:39 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The curbside light is the first one in the series according to my 75 service manual. The other two get their power in series from this one. If the curbside one is the only one not working, maybe it is the socket...
Richard
Old 11-14-2011, 08:01 AM   #3
SteveH's Avatar
Common Sense , Texas
I've got the same problem on my trailer...the curb side, middle clearance light has no power. I've checked the bulb, and the socket, and the ground. There is no power at the socket, and the ground is good.
I figured the next thing to do is cut a hole in the inside wall where the light is, but have been reluctant to do it, so it's still out.
I take it in for safety inspections when I know they will be real busy, and so far they have not noticed it.
Regards,
Steve
Old 11-14-2011, 09:33 AM   #4
Clearance light wiring can easily be fed from a clearance light that is working, to one that is inoperative.
That applies to the front as well as the rear clearance lights.
Old 11-14-2011, 05:32 PM   #5
1974 25' Tradewind
thanks , I will fish to the one next to it, just odd that the first unit is out. Andy years of experience I can see has taught you how to work around problems.
Old 11-23-2011, 05:24 PM   #6
casa3805's Avatar
Corpus Christi , Texas
Images: 41
me too
My street side clearance light went out. Definitely not the bulbs. Did you manage to fish those wires over? My LED replacements were supposed to show up today (but they didn't) and we hit the road in the morning so I guess I go without one. Just trying to see how hard that was for you and if you had plenty of slack to make it work.
Chuck & Skye
Rock and Roll Will Never Die!
WBCCI 3805
AIR 54011 Since July 2011
casa3805 is offline   Reply With Quote
Old 11-24-2011, 12:23 PM   #7
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Did you make sure it has a good ground? Have you checked to see if there is 12 volts at the fixture?
Old 11-24-2011, 07:34 PM   #8
casa3805's Avatar
Images: 41
Not yet. Had to load up and leave. But my new led replacements for all clearance lights showed up so maybe while everyone else is our for black friday I can check it out. And too funny...we pulled into the campground and the first thing we saw was a dozen Airstreams. Alamo unit rally. Before we even parked we were being invited over. Gotta luv the Airstream community!
Chuck & Skye
WBCCI 3805
Old 11-27-2011, 10:48 AM   #9
SteveH's Avatar
It was nice meeting you, Chuck. Wish y'all could have joined us, but we understand with you having family there, and all.
Maybe next time. Watch the Rally Forum here as I've been posting our rallys, and our next one is January 20-22 at the Rio Raft RV Park on the Guadelupe River just below Canyon Dam.
Regards,
Steve
Old 11-27-2011, 01:31 PM   #10
RGates
Randy Gates's Avatar
1968 20' Globetrotter
Thousand Oaks , California
I have a 1968 GT and have taken her apart and remember that AS ran both harness wires through a base frame channel where the back storage/battery door was. It met up and ran to the passenger or Rt side down near the waste tank by the steel frame. Mine had alot of rust and the wires were fried there by the frame. Another place to check is your main plug to your trucks hook up. Sometimes corrosion can cause the lites to go inop. Good Luck.
Randy
Randy Gates is offline   Reply With Quote
Old 11-27-2011, 03:41 PM   #11
casa3805's Avatar
Images: 41
So sorry
Wish we could have gotten down there, but this was all about grandkids and the Christmas Dickens festival downtown. I really thought we could make it down for happy hour but the festival started at about 5 and happy hour was at 4 so.... we will do it next time!
I did figure out it was a grounding problem, so no big deal with my lights. They are good to go.
Chuck & Skye
WBCCI 3805
Old 11-27-2011, 06:35 PM   #12
SteveH's Avatar
We understand, and it was good meeting you. Glad you got the lights fixed.
Regards,
Steve
Old 11-27-2011, 08:15 PM   #13
casa3805's Avatar
Images: 41
rust
I pulled the light that was not working and saw rust where the screw connected to the ground. A little bit of scraping and all worked. Then I pulled a couple others and saw the same thing. Also lots of dark black gunk, that at first I thought was just road grime getting in or something. But now, I think it may have been the original gasket material that deteriorated over time and fell inside the lens cover. No gasket meant moisture could get in, and thus the rust on the screws. New LED replacements have a rubber grommet instead of a gasket. So... I think this mystery, for me, is solved. Hope the OP has had good luck as well.
Chuck & Skye
WBCCI 3805
Street side brake light not working w/ running lights on NicheVintage Lights - Interior & Exterior 7 08-23-2011 05:54 AM
Running light won't turn off terryd Lights - Interior & Exterior 4 07-20-2011 07:41 PM
Sealant for Running Light Connector?? tinbender Lights - Interior & Exterior 4 07-18-2011 11:31 AM
1988 Running Light Exposed Wire vhariable Lights - Interior & Exterior 2 06-25-2011 08:56 PM
Running light issue solved! Phrunes Lights - Interior & Exterior 0 06-12-2011 09:30 PM
