Old 06-21-2015, 02:41 PM   #1
Houston , Texas
Running light broken off - trip coming
Hi, I was careless backing the trailer into the storage unit and broke off a running light next to the trailer door (2015 27FB). We leave in 3 days for a 2 1/2 week trip to Yellowstone. I am worried that the broken wire might blow a fuse or worse when the lights are turned on.
Any suggestions?
ID:	241247   Click image for larger version
WayneS is offline   Reply With Quote
Old 06-21-2015, 02:47 PM   #2
Morgan guy's Avatar
2007 27' Classic FB
Fredericksburg , Texas
It appears that the power lead is outside the trailer. You could for a temporary measure put a wire nut on it to protect it from shorting out. I would also tape the two wires together so they don't pull back inside the shell.
It would not be hard to find a replacement and install it. It is not a difficult job.
The Tex-i-can is Ready to Camp
Morgan guy is offline   Reply With Quote
Old 06-21-2015, 02:52 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
You can pick up replacement at almost any auto, rv parts store or even truck stops.
MICHAEL
Old 06-21-2015, 04:12 PM   #4
Houston , Texas
Thanks for the replies, if the white is positive then I will try covering it and see what happens when I turn the lights on. The ground wire is actually broken inside the trailer so I am not sure what the long term fix will be. we may be going to Ohio this fall!
Old 06-25-2015, 08:35 PM   #5
SipStreamer
2010 20' Flying Cloud
Lakeside , Montana
Keep in mind the legality or illegality of not having all the required running lights working.
StreamDog is offline   Reply With Quote
1968 Overlander Running Light (Marker Light) Wiring Diagram or Routing Information Bunkroom Lights - Interior & Exterior 0 08-24-2014 04:12 PM
Running light won't turn off terryd Lights - Interior & Exterior 4 07-20-2011 07:41 PM
1 tail light only works when running lights are 'off' 71safari Lights - Interior & Exterior 8 09-14-2009 01:52 PM
The welder is coming, the welder is coming... Safari Tim General Interior Topics 13 09-01-2006 10:00 AM
The Airstreams are Coming!! The Airstreams are Coming!! j54mark Airstream "In the News" 7 07-07-2005 07:06 AM
