Old 07-03-2014, 06:46 AM   #1
1964 24' Tradewind
Lawrence , Kansas
Running Light
When I have my running lights (64 Tradewind) on my drivers side tail is not on. Brake light works, other running lights work, and blinker works but not the running light. I am not experienced with tail lights so I thought I might ask for some guidance before taking off the light to look. Thanks.
ttbikes is offline   Reply With Quote
Old 07-03-2014, 06:52 AM   #2
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
It is probably a dual filament bulb with one filament burned out.
BambiTex is offline   Reply With Quote
Old 07-03-2014, 07:55 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
YES. If the brake light works the fixture is grounded. Thus a filament in the bulb or a broken wire to that point in the socket. Most likely the bulb.
2004 Excursion 4x4
Old 07-03-2014, 10:15 AM   #4
1964 24' Tradewind
Lawrence , Kansas
I was hopping for that. Thanks I will give it a try.
77 argosy running light wiring help? Tamara Lights - Interior & Exterior 4 05-10-2007 05:02 AM
Running Light Leaks bhunt Lights - Interior & Exterior 4 05-15-2006 11:18 AM
Please help determine MAX running light wattage Westfalia Electrical - Systems, Generators, Batteries & Solar 4 01-17-2006 01:50 AM
Running light question jcferguson Lights - Interior & Exterior 9 11-01-2005 09:07 AM
Retainer Screw on running light? stevepdx Lights - Interior & Exterior 1 02-05-2005 03:43 AM
