Old 08-03-2009, 01:02 PM   #1
pinktrailer's Avatar
1967 26' Overlander
1953 17' Clipper
Mendon , Vermont
Round outlet for '53 exterior
My electricians just ran new wires for my '53, installed the round inlet box that I purchased from VTS, but we all decided that the rectangular OUTLET box that I ordered would be just too ugly on the front of the trailer. Originally, both exterior boxes were round.
Any ideas where I can find one? Thanks for any help.
pinktrailer is offline   Reply With Quote
Old 08-03-2009, 01:33 PM   #2
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Electrical Shore Connection
Without a picture of the hole in your '53, its hard to tell if this is the one or not. This is what my '59 had on it originally. Wish I had kept this one to put on. Its a Theo Bargman 60-0-03 and they turn up from time-to-time but the hard part is finding the cord end plug that goes into this connection. You can see the cord end on the next post.
Good luck and let us know if you find a source.
FF
On edit: I can't get the second picture to load. I'll keep trying.
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 08-03-2009, 01:39 PM   #3
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
I'll try to get the picture to load with another post. This is a pic of the cord end you'll need to find as well.
FF
Old 08-04-2009, 03:50 AM   #4
1967 26' Overlander
1953 17' Clipper
Mendon , Vermont
Bargman outlet
Thanks for the pic and the info. Mine is a Bargman 58-0-8. If I knew how to load a picture, I would send you one. It's a two prong plug receptacle, and the cover slides across from the left and hooks onto a large grommet. It is in perfect shape. Maybe I'll just put it back on the trailer as a "dummy", until I can figure out what else to do.
If I can figure out how to load pictures, I'll send some later.
Exterior outlet RLS Electrical - Systems, Generators, Batteries & Solar 10 06-22-2009 10:37 AM
Adding Exterior Outlet Ganglin Lights - Interior & Exterior 4 09-18-2007 09:27 PM
Exterior electrical outlet cover airstream4 Exterior Restoration Forum 1 12-05-2004 01:37 PM
Help!! exterior outlet cover stuck TheBigRedTruck Electrical - Systems, Generators, Batteries & Solar 8 06-28-2002 11:04 AM
Exterior 120 volt outlet cover thenewkid64 Electrical - Systems, Generators, Batteries & Solar 8 06-16-2002 08:54 AM
