08-25-2016, 04:18 PM
1977 Argosy 24
Gilbert
Reverse Polarity Light
Having just read about reverse polarity lights, I am assuming that the light at the left rear side of the trailer above the water inlet is just such a light. How can I test it to see if it is working?
Cheers....John
1977 24ft Argosy - sold.
08-25-2016, 05:22 PM
1974 Argosy 26
Morrill
, Nebraska
You are correct it is the reverse polarity light.
IMHO you should disconnect it. But if you want to test it you need to reverse the hot and neutral in the panel. The light is wired between the neutral and earth ground. So if the hot and neutral are reversed the light will come on. But only if the bulb is good.
There are testers out in the market place that plug into a standard duplex outlet in your coach that will give you much more info on whether the wiring is correct.
I believe the price of these testers is less than $10.
08-25-2016, 07:27 PM
1977 Argosy 24
Gilbert
So really I just need to test the bulb. Thanks
Cheers....John
08-25-2016, 08:15 PM
I think that the reverse polarity light is a cool feature
I am curious as to why you would advise to disconnect it. I'm shocked !!
I dry camp. I have only stayed at two campgrounds, one of which where the warning light came in handy, and saved me from getting shocked.
Another time at a " farm party " I daisy chained on to my friends camper. My friends extension cord was bad and my daughter was barefoot and got shocked when she tried to open the camper door.
08-27-2016, 08:10 AM
1974 27' Overlander
Baltimore
, Maryland
The reverse polarity light could provide a path to energize the frame if polarity is reversed. It's better than nothing, but there are better solutions for ensuring safe power.
I'm shocked!
I see what you did there.
08-27-2016, 09:10 AM
1977 Argosy 24
Gilbert
Can you give some examples
Cheers....John
08-27-2016, 10:38 AM
2000 25' Safari
Davidson County
, NC Highlands County, FL
a better option for $5-$10, available at most hardware stores.
I leave mine plugged in 100% of the time when on shore power. It also is a pretty good night light.
Alan
08-27-2016, 11:29 AM
1974 27' Overlander
Baltimore
, Maryland
The whole mode of operation is to provide a path from the neutral leg to the frame through a bulb. Energize the neutral leg, the energy travels through the bulb to the frame, i.e. energizing the frame. Probably not dangerous since the bulb provides some resistance, but again, there are better solutions available.
08-27-2016, 11:30 AM
1977 31' Sovereign
1989 34' Excella
Johnsburg
I prefer the non-contact voltage detectors which tell you immediately if the polarity is switched and has energized the trailer skin or frame. Here is the link to a $10 one from Sears I bought for our local club: [URL="http://www.sears.com/craftsman-voltage-detector/p-03482174000P?sid=IDx01192011x000001&gclid=Cj0KEQjw 9IS-BRC4qZXagbLs6uMBEiQAYHBh-xFaOH3o9hVRiCMKuwUwkqixvcoWfkdHpK5Edy8zcWMaAveC8P8 HAQ&gclsrc=aw.ds"]
Similar devices are available $10-$20. Better safe than sorry.
08-27-2016, 11:31 AM
1974 27' Overlander
Baltimore
, Maryland
Progressive dynamics EMS comes to mind. I have the hardwired 30amp version. Won't allow power to the coach with reversed polarity, along with a laundry list of other power problems.
08-27-2016, 12:40 PM
Overland Adventurer
2009 34' Panamerica
Telluride
It is not a bulb... its a neon capsule.
08-27-2016, 04:15 PM
1977 Argosy 24
Gilbert
Does it ever burn out
08-27-2016, 10:33 PM
2007 22' International CCD
Corona
Neon bulbs don't usually burnout, but the do get dim overtime
08-28-2016, 04:11 AM
1977 31' Sovereign
1989 34' Excella
Johnsburg
The only way to reliably test a neon capsule is to energize it with 110 volts AC. It is best to unsolder it, test it, and reinstall it in the circuit. I do not recommend reversing the trailer input power. This can pose a potential danger to some equipment and personnel.
08-28-2016, 08:00 AM
1974 Argosy 26
Morrill
, Nebraska
A W Warn posted the device I was referring to. Get rid of the old light.
08-28-2016, 08:44 AM
Yeah, I am still confused
I'm thinking that the frame would be hot, if the polarity is reversed, even if you didn't have a warning light.
I perceive your comment to mean that a faulty warning light could cause the exact problem that is supposed to be warning you against. Am I correct????
08-28-2016, 09:04 AM
2002 30' Classic S/O
Fleming Island
The main difference is that the bulb limits the current, which is not the case when the Polarity is reversed. The neon bulb will not light and pass any current until the voltage across it is above the ionization potential for neon which, if I recall correctly, is about 90 volts. This won't happen unless there is a low resistance connection between the frame and ground. If the tongue jack or stabilizers or body contact provide this the bulb might light and energize the frame but the available voltage would only be about 30 volts. That's better than 120.
But it is zero if the bulb is replaced with a plugin tester.
Al
05-06-2017, 08:11 PM
62 Flying Cloud
1962 22' Flying Cloud
Lakewood Ranch
Seems an odd place inside a closed hatch as a warning device
05-07-2017, 04:56 AM
62 Flying Cloud
Lakewood Ranch
My son says he was zapped when it was raining. What can I do to prevent zapping?
05-07-2017, 07:03 AM
1974 Argosy 26
Morrill
, Nebraska
Check the 120 volt wiring. Somewhere between the source and the coach the hot wire and neutral are reversed.
What are you using to provide power to the coach?
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Reverse Polarity - Need Help
StreamAholic |
Electrical - Systems, Generators, Batteries & Solar |
8 |
07-18-2015 06:13 PM |
Polarity light
batt |
9 |
10-31-2011 06:08 PM |
polarity light
scotty2hotty |
17 |
05-29-2010 11:41 PM |
Polarity Light - 1968 Safari
hockeyrink |
12 |
03-19-2010 09:27 PM |
Polarity light function (diode?)
walter1 |
12 |
09-03-2004 02:59 PM |
