Old 08-28-2016, 08:00 AM   #15
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
A W Warn posted the device I was referring to. Get rid of the old light.
Old 08-28-2016, 08:44 AM   #16
mandolindave's Avatar
Yeah, I am still confused
Originally Posted by TheGreatleys View Post
The reverse polarity light could provide a path to energize the frame if polarity is reversed. It's better than nothing, but there are better solutions for ensuring safe power.
I'm thinking that the frame would be hot, if the polarity is reversed, even if you didn't have a warning light.
I perceive your comment to mean that a faulty warning light could cause the exact problem that is supposed to be warning you against. Am I correct????
mandolindave is offline   Reply With Quote
Old 08-28-2016, 09:04 AM   #17
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
The main difference is that the bulb limits the current, which is not the case when the Polarity is reversed. The neon bulb will not light and pass any current until the voltage across it is above the ionization potential for neon which, if I recall correctly, is about 90 volts. This won't happen unless there is a low resistance connection between the frame and ground. If the tongue jack or stabilizers or body contact provide this the bulb might light and energize the frame but the available voltage would only be about 30 volts. That's better than 120.
But it is zero if the bulb is replaced with a plugin tester.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 05-06-2017, 08:11 PM   #18
62 Flying Cloud
VooDooLounge's Avatar
1962 22' Flying Cloud
Braden River , Florida
Seems an odd place inside a closed hatch as a warning device
VooDooLounge is offline   Reply With Quote
Old 05-07-2017, 04:56 AM   #19
62 Flying Cloud
My son says he was zapped when it was raining. What can I do to prevent zapping?
Old 05-07-2017, 07:03 AM   #20
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Check the 120 volt wiring. Somewhere between the source and the coach the hot wire and neutral are reversed.
What are you using to provide power to the coach?
Reverse Polarity - Need Help StreamAholic Electrical - Systems, Generators, Batteries & Solar 8 07-18-2015 06:13 PM
Polarity light batt Electrical - Systems, Generators, Batteries & Solar 9 10-31-2011 06:08 PM
polarity light scotty2hotty Electrical - Systems, Generators, Batteries & Solar 17 05-29-2010 11:41 PM
Polarity Light - 1968 Safari hockeyrink Electrical - Systems, Generators, Batteries & Solar 12 03-19-2010 09:27 PM
Polarity light function (diode?) walter1 Electrical - Systems, Generators, Batteries & Solar 12 09-03-2004 02:59 PM
