Old 03-11-2012, 08:24 AM   #1
1971 23' Safari
MUSCLE SHOALS , Alabama
Replacing Tail Lights
I have a 1971 Safari 23 foot with (cheap) retro-fit tail lights mounted over the original tail light housing.
To replace these retro lights, I purchased the canister type 1156 and 1157 light fixtures (originally used by Airstream from 1969-1974) which fit into the existing (original) tail light housing.
Before disconnecting the retro-fit lights I checked to see which filament in the 1157 bulb burned when applying the brakes and verified it was the bright filament.
When I removed the retro-fit light and installed the new 1157 canister, the dim filament burned. It's the same scenario when I checked the turn signal, retro burned bright, new canister burned dim.
What's the problem?
equigley is offline   Reply With Quote
Old 03-11-2012, 09:42 AM   #2
What's the problem?
Obviously, a bad ground is causing that issue for you.
Mahalo
Old 03-11-2012, 10:00 AM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Photos would help.
The first troubleshooting areas I would do, maybe you already have, is a poor ground or partial short.
Old 03-16-2012, 07:44 PM   #4
1971 23' Safari
Thanks all. You were correct, the problem was a poor ground. This project is back on track.
Thanks again.
Old 10-31-2012, 08:03 PM   #5
1971 29' Ambassador
guyton , Georgia
tail lights wirening on a 1971 ambassador
r.swanson is offline   Reply With Quote
replacing 1141 incandescent bulbs with LED Globie64 Lights - Interior & Exterior 28 07-20-2014 10:09 PM
Driver side brake lights do not work 82 excella General Repair Forum 17 03-16-2012 04:40 PM
where to find tail lights for '78 esmaytum Lights - Interior & Exterior 2 03-15-2012 02:08 PM
Trailer reflector lights colleengray Exterior Restoration Forum 1 03-10-2012 11:45 PM
Nice looking Ikea low-voltage wall lights chromis Lights - Interior & Exterior 9 03-09-2012 06:21 PM
