Old 03-05-2019, 09:56 AM   #1
Woodside , California
Replacing Tail Light LEDs in 2014 FC
I just purchased a used 2014 FC from a private party. In the inspection (thank you David Johnson) it was noted that there are a few LEDs in the tail lights that are not working. I'd like to replace them, and have found a source to purchase, but am not sure of the best way to get access to the back of the light. Does the entire light unit, including frame, come off or is it just the smaller section in which the lights are housed? Anyone having this experience I'd be pleased to learn what you know.
Gary
ghanesdvm is offline   Reply With Quote
Old 03-05-2019, 10:19 AM   #2
2014 25' Flying Cloud
Temple , Texas
Replace the entire light - they are available just about anywhere, the biggest issue is the shiny plastic that fits around the light,
2014 Flying Cloud 25FB
2018 Ram 2500; Diesel
Blue Ox WDH
RamRider is offline   Reply With Quote
Old 03-05-2019, 12:43 PM   #3
Thanks. Yes, I do find them available on line. I just have a fundamental issue with replacing the entire unit, most of which is still working, rather than just replacing the bulbs. Must be a California thing. I do appreciate the suggestion.
Old 03-07-2019, 05:21 AM   #4
2017 30' International
Charlotte , North Carolina
With LED unit you must replace the whole unit, the individual LEDs are soldered into a circuit board and the whole thing sealed.
Al U. Minium is offline   Reply With Quote
Old 03-08-2019, 09:33 AM   #5
Replacing LED tail lights, 2014 FC
Thanks for the helpful suggestions. Yes, removing the chrome bezel is best done with a paint can opener and flat screwdriver, being careful not to chip the edge of the bezel. Four tabs hold it in place. Once removed the sealed tail light assembly comes off with four screws. there is no way to access the individual bulbs so the entire unit is replaced with one costing less than $30.00. A new bezel is about $7.00. Three wires into the lamp assembly which may need to be cut and spliced but I haven't received the replacement yet to know for sure.
Easy job to do yourself.
Gary
$5 Retrofit LEDs for 6-light ceiling lights in '73 Overlander aquinob Lights - Interior & Exterior 48 05-14-2015 01:36 PM
Anyone know of LEDs for the rear marker lights on mid '70s on the tail lights? Mixter Lights - Interior & Exterior 8 11-11-2014 09:27 PM
Marker Light LEDs for Teardrop robwok Lights - Interior & Exterior 0 09-12-2014 09:09 AM
Leak near tail light, but it's not the tail light adwriter73 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 03-31-2013 12:34 PM
Less LEDs more light Dan@LED4RV Commercial Listings 18 07-16-2010 11:17 AM
