Old 08-18-2012, 08:47 PM   #1
1973 23' Safari
Smithfield , Virginia
Replacing old Tail Lights
I finely have gotten around to replacing the Incandescent tail light/Brake Light with some LEDs I picked up awhile ago. When I removed the old lights I found what looked like, to me, some type off fiber optics cable connected to the center of the metal can that holds the light bulb. Does anyone know what these cables are and what theyíre used for? Iíve made all the connection but havenít finished the install yet and am wafting for some more info. Thanks
jasmith58 is offline   Reply With Quote
Old 08-18-2012, 09:01 PM   #2
Those fiber optic cables are the tail light monitor thats on the left side of your Airstream.
They can sometimes still be used with LED light replacements.
DO NOT cut those cables.
Old 08-19-2012, 05:45 AM   #3
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
If anyone has successfully linked the fiber optic cable to an LED replacement - would you please share how you did that......
Old 08-19-2012, 10:19 AM   #4
A #21 drill bit, works perfect.
Drill the hole ONLY thru the "BLACK PLASTIC".
Old 08-19-2012, 01:07 PM   #5
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
thanks Andy appreciate the tip - but, mine don't have any black plastic. guess I'll live without it.... I do miss the indicator - it's a nice feature
Old 08-19-2012, 05:41 PM   #6
1973 23' Safari
Hi Andy,
After I posted the question I found the answer looking through the threads.
I didn’t cut the fiber optic cables, I just stuffed them inside. I got the replacement LED taillights from you a couple of years ago. They have a white plastic back. Can I Still connect the tail light monitor system?
I had to finish the install today because I’m taking the trailer for a state inspection first thing tomorrow, but would consider pulling it all apart to get the tail light monitor system back.
Old 08-19-2012, 05:57 PM   #7
Hi Andy,
I didnít cut the fiber optic cables, I just stuffed them inside. I got the replacement LED taillights from you a couple of years ago. They have a white plastic back. Can I Still connect the tail light monitor system?
I had to finish the install today because Iím taking the trailer for a state inspection first thing tomorrow, but would consider pulling it all apart to get the tail light monitor system back.
Drill a hole dead center on the backside with a # 21 drill bit.
Drill thru the first layer of plastic, ONLY.
Old 08-19-2012, 06:00 PM   #8
Hi Andy,
Drill a hole dead center on the backside, but do not go beyond the first layer of plastic.
Try that and see what happens.
