Old 08-20-2012, 09:28 AM   #1
tksbaskets's Avatar
2007 25' Safari FB SE
Dexer , Michigan
Replacing burned out patio light 2007 Safari
Hi,
Is there some trick to getting the cover off to replace the bulb on the outside patio light? DH and I can't seem to figure it out.
T
tksbaskets is offline   Reply With Quote
Old 08-20-2012, 10:35 AM   #2
btowntincan's Avatar
Mercer Island , Washington
Should be just three screws that hold it in. It has a gasket that may be holding it on still, but it comes right out. I just replaced mine with an LED a few weeks ago, was not a problem.
btowntincan is offline   Reply With Quote
Old 08-20-2012, 11:03 AM   #3
Morgan guy's Avatar
2007 27' Classic FB
Fredericksburg , Texas
Do you remember what LED bulb you used. I want to change my bulb also.
Ron
Morgan guy is offline   Reply With Quote
Old 08-20-2012, 12:04 PM   #4
I bought the assembly from Dan at LED4RV.com. It's a replacement of the lens too (mine was a bit melted). I think it was around $25. Give him a call and he'll know which one works for you.
By the way, it's really bright.
Old 08-20-2012, 07:23 PM   #5
tksbaskets's Avatar
Dexer , Michigan
Thanks! Our cover is a little melty too and the gasket looks like it melted a bit too. Was the LED hard to install?
TK
Old 08-20-2012, 11:08 PM   #6
Insanely easy. Took all of 5 minutes. To install the gasket, it helped that my son was walking by - helped to have an extra set of hands to hold it all together when installing the screws, but I probably could have done it too.
Old 08-21-2012, 09:20 AM   #7
tksbaskets's Avatar
Dexer , Michigan
Super news! I emailed Dan from his web site last night and he wrote me right back with the link to the assembly I needed. It's on the way. I've told my DH that you said it's easy to install. I'll let you know.
Thanks so much for the tip!
TK
Old 08-24-2012, 05:36 PM   #8
tksbaskets's Avatar
Dexer , Michigan
My hubby got the new light in and it was slick! He agreed that the toughest part was getting the screws in. We are very happy that to have the light changed over. It was burning really hot before.
Thank you for all your help!
TK
Old 08-25-2012, 08:49 AM   #9
Dan@LED4RV's Avatar
Denton , North Carolina
putting the lens back on
Originally Posted by tksbaskets View Post
Hi,
T
The screws may be tight and hard to get to move. You may try some penetrating oil. I would not put so much it runs onto the side of the unit.
To put the lens back on, I put the lens in place and eye ball the holes to see if they line up, and apply pressure in the center of the lens. Start the first screw (don't tighten) then start the next one. If the 3rd screw proves to problematic take the pressure off of the lens and see if the if you can get it to line up then.
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 08-26-2012, 07:22 AM   #10
tksbaskets's Avatar
Dexer , Michigan
Hi Dan,
My original post was before btowntincan turned me on to your company. DH did just what you described below and our new fixture went in without any issues. It is a nice bright light and we are not worried about it melting
Thanks everyone!
Old 08-26-2012, 09:20 PM   #11
Lyle & Margie
2008 28' International CCD
Lakeside , California
Dan, are we talking about the "scare light" or the light above the door (like our '08 Intl)?
Lyle & Margie
BAB BMRZ is offline   Reply With Quote
Old 08-26-2012, 11:06 PM   #12
Dan@LED4RV's Avatar
scare or patio light
Lyle & Margie
The scare light which some people call the patio light.
Dan Brown
Denton NC
Old 08-26-2012, 11:18 PM   #13
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Lyle & Margie
Hi, like this.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
