Old 03-06-2012, 12:22 PM   #1
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
replacing 1141 incandescent bulbs with LED
I've seen numerous posts on replacing lamps and fixtures, and more numerous sites online to find LED replacement lamps (lamp=bulb). What are people's experiences with these lamps and online lamp sellers? I've used some LED products in residential projects and have found out the hard way that there is a broad range in quality, and that some can fail prematurely. So, if anyone has some good experiences with replacement bulbs or fixtures to replace the multi-lamp fixtures found in the early 60s trailers. I did find this
W.A.C. Lighting *>*Products*>*Cabinet and Niche lighting*>*Light Bars*>*LEDme Light Bars > BA-LED2
WAC makes good stuff...
Thanks!
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 03-06-2012, 12:26 PM   #2
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Hi from GA. . .there are a lot of threads on this subject if you search LED lights. I think most people like them (me included) but they are pricey. Regards, Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
Old 03-06-2012, 12:50 PM   #3
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
I replaced all 20 of the interior regular lamps in my 66 Tradewind with 10 LED bulbs, and I am very happy with the results. I also replaced the exterior spot light with an LED. This step is essential if you run off the batteries (boondocking) since you only use about 10% of the battery power and therefore only generate about 10% of the heat compared to normal lights. You can see my posts (37, 39 and 40) in the following thread "To LED or not":
http://www.airforums.com/forums/f447...d-79632-3.html
I hope this helps someone.
Dan
Old 03-06-2012, 01:42 PM   #4
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
I also replaced all of the lights in my 65 Safari w/LEDs and am very happy. I also added above and below cabinet LED strip lights. All are Warm White in color.
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 03-06-2012, 02:36 PM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Used both of these vendors with very good results...
LED Lights, Bulbs & Accessories - SUPER BRIGHT LEDS
LEDs 4, Recreational Vehicles
“Not enjoying the Network News Broadcast?…ask your Doctor." 🤪
RLC
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 03-06-2012, 03:28 PM   #6
dznf0g's Avatar
Oswego , Illinois
Interesting! Over time these are the same two vendors I have settled on. I used Super Bright for automotive replacements for about 10 years (long before I had my AS) and I have used LEDs 4 RVs for all my AS replacements.
-Rich-
Old 03-06-2012, 03:51 PM   #7
heslinhotel's Avatar
1989 29' Excella
1974 Argosy 26
1999 25' Safari
Youngsville , North Carolina
Globie64
I just finished removing 10 interior fixtures in my 29'. Replaced all with warm white LED strip lights from "Superbright leds". Also installed dimmers on the circuits. On the exterior, I installed LED replacement bulbs in spotlight, door light, brake lights and back up lights. Very pleased with results.
I am working on installing a waterproof yellow LED strip light with dimmer on exterior curbside. Planning on removing small blue insert and mounting strip light in its place. Before I complete install I want to see if yellow light keeps bugs away, if it doesn't will use another color probably blue.
Will try and attach pic's.
ID:	152690   Click image for larger version
ID:	152692   Click image for larger version
ID:	152694   Click image for larger version
heslinhotel is offline   Reply With Quote
Old 03-06-2012, 05:58 PM   #8
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
Yup, I too replaced all my interior lamps with LEDs - but only the under-step exterior ... did it for amp-hour conservation reasons. Tried several vendors, tried several configurations. What seems to work best for me is the Superbright LED "circuit board" style - I just put them right into the existing fixtures. I tried double-sided tape to hold them in place but that didn't work so well, so reverted to the old tried-and true method ... no, not duct tape - a tiny little dab of silastic at each corner. They work fine and draw about 1/7 of the current of teh original lamps. I think they are not quite as bright and they're a bit pricey per lumen, but they're fine for me. No failures, no regrets. I'd do it again in a second.
AirsDream is offline   Reply With Quote
Old 03-06-2012, 07:24 PM   #9
1989 29' Excella
1974 Argosy 26
1999 25' Safari
The main reasons for my conversion to LED strip lights was two fold, first was cost (the interior conversion was under $100), the second was the ability to adjust brightness via dimmer switches. I can't belive the price they ask for individual bulbs. I was not willing to spend that kind of money.
Old 03-07-2012, 09:02 PM   #10
Globie64's Avatar
Images: 18
thanks for all the great tips! I've used the strip lighting (the rolls) in projects for clients and like the effect, but for me, it would be to glare-y for direct lighting, but it is a great idea for indirect. I had been noodling around with what to do to replace the semi-recessed rectangles in the ceiling, maybe using the strips...
Mostly, I was looking for reputable vendors through the experiences of others, and this helps. I think the RV LED guy is a forum member? Thanks again
Old 03-07-2012, 09:58 PM   #11
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
Just finished the LED project tonight. I bought from Airstream and Superbright LED as others mentioned. I got some tower bulbs and the pcb or circuit board type. The 30 LED circuit light is brighter from superbright than the 24 LED airstream store boards. The 45 light tower is POWERFUL. It is a replacement for the 1156. I used one of them for the patio light and the wardrobe. The oven hood bulb I replaced with a 30 LED pad and it is amazing the light it puts out. Altogether it was about $300 to do the interior (including reading lights) patio and door light outside of my Safari.
Old 03-07-2012, 10:07 PM   #12
Globie64's Avatar
Images: 18
I'm looking for lamps to replace the ones in the original wall mounted bullet fixtures, 1141 lamps now to replace with some kind of small spot. The lighting they give is excellent, directable and with no glare, and I like indirect lighting. I found some great fixtures for the ceiling fixtures, but a hundred bucks a pop.
Old 03-07-2012, 10:13 PM   #13
2006 25' Safari
Images: 8
I have ceiling fixtures that take 1141/1156 bulbs but if you need a bulb shape the 45 LED tower bulb from superbright is powerful and comes close to matching the 1156 for light. It is also available in warm white. It is not cheap though. About $25.
Old 03-07-2012, 10:15 PM   #14
Globie64's Avatar
Images: 18
Thanks Rodster... If it lasts, 25 bucks isn't so bad. The old auto lamps are a couple of bucks, but if the LEDs last, it's also about energy saved and the battery hassle, I'd say.
LED light kit for the Monarch stop tail and turn light Dan@LED4RV Commercial Listings 6 07-03-2018 12:26 PM
Finding LED replacement bulbs with long life johnobuttons Lights - Interior & Exterior 5 11-28-2011 02:27 PM
To LED or not to LED? SilverHoot Lights - Interior & Exterior 56 10-03-2011 01:15 PM
Replacement LED fixture under front cap Pat Conway Lights - Interior & Exterior 2 04-12-2011 02:22 PM
Lens melting w/1141 bulbs HCR Lights - Interior & Exterior 9 03-04-2011 01:37 PM
